please help troubleshoot
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tee Bone, Sep 29, 2020.
  1. Tee Bone
    Tee Bone New Member
    Redondo Beach
    Hello all,
    I have a gen 3 2012 prius, my hatchback will only shut when I slam it closed. I inspected the latch mechanism and it seems to working, i can close it manually and then with the press of the button it will open. I checked to see if there was some molding or something similar causing the problem, I didn't find anything like that. How likely is that this is because the latch needs replacing?
    Thanks in advance for any help and clarity
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
  3. ChapmanF
    15,578
    I wish that were normal for mine. I can't avoid mine latching no matter how gently I let the hatch down. If I ever want to just lower the hatch for a moment without latching it, I can only do that by closing the latch with my pinky finger first, and then using the release button later when I want to really close it.
