Please help with a Master Warning Light Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cpagal, Aug 19, 2006.
  1. cpagal
    cpagal New Member
    Hello. I am a new Prius owner having just gotten my 2006 Prius less than 2 months ago. Tonight I was sitting in my living room and heard what I thought was a car alarm going off. I looked out the window and my Prius' lights were going off & on and the horn was sounding. I ran outside to the car to see what was going on. I got into the car and somehow got the horn to quit sounding (I have no idea how though). I tried to power it up. The dash lights came on, but the MFD did not. One of the warning lights showing on the dash was the big triangle light. I tried to put the car in reverse to see if it would move and it wouldn't. I then turned to car back off & tried to power it up again with the same results.
    I went into the house to tell my husband that the Prius was dead. After a few minutes I went back outside to get the owner's manual. While there I tried to power up the car again. This time it came up just like normal. I looked at the MFD I had about 6 bars on my battery. I sat in the car for maybe about 3 minutes just looking at the book and gauges and such and all of a sudden my battery was at 2 bars.
    I drove the car around a little bit and the battery regained it's charge and the light did not come back on.
    Does anyone have any idea what happened?
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    All that noise sounds like the alarm system was triggered or the Panic button on the fob got pushed. I can't imagine why it wouldn't start, unless you were upset and did something amiss, which I'm not suggesting. If all those lights came on, it may have set a code. I'd suggest you take it to the dealer on Monday, if you can, describe what happened, and see if they can pull a code. Starting the car repeatedly will clear some codes. If you can get the code and tell us, we may be able to help. Lot's of smart Prius people here.
    Sometimes strange things happen, but it's good to try to figure out why. Good luck and keep us posted.
    It really is a great car. Welcome to PriusChat!
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    well, there are 2 possibilities. first, someone could have set off your car alarm, in which case it was doing its job. otherwise, the car set it off itself, which can be caused by a low 12v battery if i recall correctly.
    all the dash lights come on when you put the car into one of the non-ready modes, and the car won't go into drive or reverse. or are you referring to the speedometer cluster?
    the second time when you did get the car into ready, you didn't see any sign of the triangle light then?
    did you have the air conditioning on while you were sitting in the car? that would drain the battery since the compressor is electric.
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    It's also possible with the SKS to get out of the car and walk away while it's still on. Leave it sitting for a while with lights, A/C or something else on, and that's a good way to drain your 12v and set off the alarm (if a low 12v sets off the alarm as Galaxee suggested).
    I've walked away from my car without hitting "power" 1 time, but I'm in the habit of locking the doors whenever I get out, so when it beeped at me a few times and wouldn't lock I figured it out.
  5. cpagal
    cpagal New Member
    The lights that came on were the dash lights and where the warning lights are at. When I finally got it in the ready mode, the triangle light was not on. The part that worried me the most was when the MFD did not come on.
    Bill could be absolutely correct in stating that I didn't do something right. I'm still new at this & I was definitely in a panic. There is a possibility that I could have accidently put it in the accessory only mode and didn't realize it. But I thought that the MFD came on even in accessory only mode.
    And, yes, I did have the air conditioner on. I knew the air would drain the battery but I didn't think it would happen that fast.
    My first thought when the lights started flashing was that my husband, who was last to drive it, did not lock the doors and it had drained the battery. But he assured me that he had locked the doors.
    I'm hoping that it was actually the car alarm going off. But the manual states it will go off if the doors are forcibly opened. Will it go off only if someone tries to get into the car?
  6. Tideland Prius
    16,621
    it's possible you had the door opened hence the red triangle.
