Please help with sound out of nowhere is it shock?
Discussion in 'Gen 2 Prius Main Forum' started by Jojo9213, Dec 18, 2018.
  1. Jojo9213
    Jojo9213 New Member
    Pawtucket r.i
    hello all i am uploading a video to see what this noise is on my 08 prius 190k has been OK untill now. just replaced driver front side strut assembly. no codes appearing. is this a stuck caliper or broken strut? it actually went away while driving I took a picture also pulled over to see if there is any obvious damage.
    thank u all #priusgang
  2. Jojo9213
    Jojo9213 New Member
    Pawtucket r.i
    i am sorry the old link does not work
    here is new one to video
  3. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    108
    27
    Wisconsin
    Sounds like the brake pads rubbing against a rough spot on the brake rotor. If it had a little surface rust from sitting for a few days, that may be why it went away as you drove.
    Generally, BTW, struts are done in pairs. Why did you replace just one?
  4. Jojo9213
    Jojo9213 New Member
    Pawtucket r.i
    @Classic_pri my mechanic said the other side was fine i guess. but now i notice it comes on when car is first warmed up or after sitting for a while then comes and goes
  5. Classic_pri
    108
    27
    Wisconsin
    The noise obviously changes with vehicle speed, so that's why I think it's related to the wheels. Wife's Prius was starting to get noisy like that at 100K miles so I replaced the brake rotors. That took care of it. Again, it was rust rather than wear that made the job necessary. The car has been driven fairly often in snowy/salty conditions.
  6. Skibob
    Skibob Senior Member
    2,912
    1,495
    Northern California
    Was the strut you replaced due to some type of damage? It’s rather unusual to replace just one.
  7. PriusCamper
    PriusCamper Senior Member
    10,895
    4,418
    Pacific Northwest, USA
    At this point, getting it up on a lift and doing a thorough inspection is key... There's a bunch of different parts that can cause noises like this... I remember I had a problem with heat shielding rattling on turns and took forever to figure it out.
