  1. JerrieAdams9216
    JerrieAdams9216 New Member
    Brea, Ca
    Hi i have a 2007 prius....night before last, we noticed that the ABS, (!), and tbe BRAKE lights did not go out when the parking brake was released. Any insight on fixing this issue. Also, for a few weeks now when i turn on my headlights , i loose my dash lights....what could be causing that to happen?
  2. JC91006
    16,494
    8,404
    Losing your dash lights is just your dimmer switch set too low. There's a wheel on the dash, left of the steering wheel, turn that wheel to adjust the dash brightness
    As for the brake, you'll need professional help unless you have a scanner and ability to fix brake issues
    Raytheeagle and SFO like this.
