Please help
Discussion in 'Gen 2 Prius Audio and Electronics' started by Diablo666, Aug 22, 2021.
  1. Diablo666
    Diablo666 New Member
    My grandparents have a 2008. Long story short grandma “hit a bush” and wrecked the passenger side doors. I went to the junk yard got 2 new doors. I stripped them down and got them painted. I reassembled the front passenger door with the original doors parts including the window motor and all the wiring. I rolled the window down before I pulled the door now all of a sudden in the new door it isn’t working. Door locks work. Out side button works and speakers work. I tried a different motor and same issue. Also swapped the harness and still had the issue. The window is stuck down all the way. Is there a reset procedure to make it work? I have yet to find an interior fuse panel. Any help will be greatly appreciated.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,422
    2,392
    Taylors, SC
    Check this video out. The window motor has to be "timed."
  3. Diablo666
    Thank you for the reply I tried the rear switch that is known to be good still nothing. The window worked 2 hours earlier when I rolled it down to unbolt the track to swap it over. I tried a second motor assembly holding it outside the door and still got nothing.
