Please help! =)
Discussion in 'Generation 1 Prius Discussion' started by karlint, Feb 25, 2010.
  1. karlint
    karlint New Member
    Oak Harbor, wa
    2001 Prius
    Hello,
    I know I am probably posting this in the wrong section. I have a question and I'm not sure where else to ask it. I am looking at purchasing a 2001 prius. I will be buying it from an older gentleman who has owned it from day one. The car has 156,000 miles on it, but he has records of all the kinks that have been fixed on it as well as putting in brand new batteries ( which he said was around 2000.00). He said he would take 5000.00 for this. Does it sound like a good deal? My problem is I am going to be using this on a rural route as a mail carrier and putting a minimum of 120 miles a day on it. Does the new battery make it almost like a new engine, how much longer do you think it will make it? I know on a regular vehicle 150K is a lot of miles.
    Any help at all would be greatly appreciated. I also wouldnt mind talking about it on the phone if that would be easier!
    Thanks so much!
    Kacie
  2. a_gray_prius
    2,927
    782
    IL
    When you say new battery do you mean traction battery? Assuming that it is, my main concern would be transmission which has begun to fail at that mileage on several members' vehicles. Repalcement of the transmission is well over $5000+ from what I have been told.
    These might be of some help:
    http://priuschat.com/forums/generat...ot-gen-1-but-need-your-advise-new-engine.html
    http://priuschat.com/forums/generation-1-prius-discussion/74920-2002-transmission-issues.html
    http://priuschat.com/forums/gen-ii-prius-main-forum/33069-2001-prius-transmission-failure.html
  3. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    My recommendation would be to stay away from it. If it was half the price, I would give it a try, but for that price, I would like to see a newer car or lower mileage.
    The Prius is a reliable car, but when it breaks, it can be more expensive to fix.
    There are millions of Corrolas around, and they are much cheaper to maintain. The gas mileage isn't as good, but your total cost will probably be lower. If you can do some work on the car yourself, that would change the equation. but otherwise, I would want something that any mechanic can work on, and where parts were inexpensive and readily available. Of course, if you had a larger budget, and could get a Prius with less then 1/2 the mileage, you should get a few years before it starts to have problems.
  4. karlint
    karlint New Member
    Oak Harbor, wa
    2001 Prius
    Thank you so much for the help! After hearing about the transmission and some of the other problems, I agree that this isnt the best idea!
  5. tf4624
    tf4624 Active Member
    526
    51
    as a person who has access to dealer prices for used cars and how that market is worth with vaules.. Not worth getting into.. Your better off getting a MUCH newer one and shoot for 2008 or better or unless good deal on 05
  6. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    I disagree - I think $5,000 for a prius with a new HV battery is a good deal. After all, I see 1-st gen models selling all day long on craigslist and ebay for MORE than that amount and they still have the original batteries in them. So what I always tell people around here looking for a Prius is that if they choose to buy one of those, better tuck away another $2,000 for a possible battery replacement. But in this case, you are good to go.
    True, a transaxle can fail, but that is far less common than an HV battery. I think the risk of a transaxle failure in a prius is no greater than the risk of the transmission failing in a normal car. True, it is expensive to fix.
    Any used car is a gamble. But I believe the odds to be in favor of the buyer here with a $5,000 Prius.
    IN FACT, if the car were around here in Texas somewhere, I could line up 3 or 4 potential buyers for the car at that price in just a few days.
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    FWIW, the 2001 Prius still has the highest reliability ratings from Consumer Reports. But it does have bad reliability ratings for its electrical system (but that may be the hybrid battery which might not be applicable here if the car has a new or used replacement hybrid battery):
    [​IMG] Prius, Yaris, Corolla Reliability History.doc
