Please id this connector.
Discussion in 'Prius c Audio and Electronics' started by Maia2u, Nov 26, 2021.
  1. Maia2u
    Maia2u New Member
    New Zealand
    2016 Aqua
    Hello, hopefully, someone can help id the connector or part name as recently I change the steering clock spring, after installing the steering audio controller and cruise controller and realise that some of the pin connectors are missing. I thought the wires and connectors are standard, so now I have to get myself the wiring harness that is lacking the pins to both connectors. Any information and guidance are greatly appreciated.
  2. djseo
    djseo New Member
    Ireland
    2015 Aqua
    Hi Maia2u,
    here are the pinouts for the black connector:
    1 - Cruise Control
    2 - Ground
    3 - TX for Combination Meter Assembly
    4 - Ground
    5 - AU2 - Audio Control 2 to radio
    6 - AU1 - Audio Control 1 to radio
    7 - Not Used
    8 - Horn
    9 - Ignition +
    10 - A/C to A/C Control Assembly
    11 - Not Used
    12 - Illumination +
Loading...
