Please post pcitures of your Prius with aftermarket wheels
Discussion in 'Gen 2 Prius Main Forum' started by CheapChic, Mar 4, 2007.
  1. CheapChic
    CheapChic New Member
    40
    Please post pcitures of your Prius with aftermarket wheels.
    Please let us know the size, offset and weight.
    thanks.
    ps, does anyone know what the stock 15 wheel weight is and of the total outer plactic part comes off for painting.
    thanks
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    17" Centerlines, 3lbs heavier than stock due to the wroing tires. I'll post more info later. :)
  3. noelty
    noelty Member
    112
    Los Angeles
    <div class='quotetop'>QUOTE(F8L @ Mar 4 2007, 08:39 AM) [snapback]399905[/snapback]</div>
    Very nice! How much for the set of wheels and tires?
  4. CheapChic
    40
    Wow, that looks great,
    How much MPG did you lose after the change.
  5. vinnysca
    vinnysca New Member
    200
    Here's mine.
  6. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(F8L @ Mar 4 2007, 09:39 AM) [snapback]399905[/snapback]</div>
    Thats cool, I noticed in your signature that you shaved you 1/4 time by more than a second from the Manufacturer ratings. B)
  7. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    Don't remember what brand these are, but they were the only 15" alloy wheel available when I bought my snow tires. They're a couple punds heavier than stock. I think they're the ugliest wheels I've ever owned.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(CheapChic @ Mar 4 2007, 11:46 AM) [snapback]399965[/snapback]</div>
    At first I thought I didn't lose any MPG but after while I had a hard time reaching the 48mpg I was getting normally. I think there were a lot of other contributing factors though. Without doing any hard calculation I would say I am probably only about 2mpg lower than I was with the stock wheels. I also have a heavy speaker box with 2 12" subwoofers and a pretty big amp so that is not helping either. Driving around from Petaluma and Point Reyes all day then back to Oakland the MDF said 50.5mpg with 160miles on the tank. Not too bad overall. My next set of tires will make my combo weight exactly the same as stock so the milage should come back some. The handling is MUCH improved!
    As for the 1/4mile time. Everything was stock at the time and I took the subwoofers out as well as the spare tire. That was the best time out of 12 runs and what I found is that the times got progressively worse the more I hot lapped it. If I ran back to back in the heat my times dropped horribly, moreso than any normal car. By the end of the day the temperature came up and I hotlapped a few times racing a Scion xB and by the last lap I was running 18.4. :( The ET is pretty bad due to the really slow take off in these cars but the MPH is actually quite good.
    The rims ran about $140/ea (Centerline direct) and I cannot remember what the tires cost but I got em from Discount Tire Direct or Tire Rack. My buddy has a performance shop so I forget who I order what from. I just grab a catelog and start calling. lol
  9. CheapChic
    40
    <div class='quotetop'>QUOTE(vinny @ Mar 4 2007, 06:47 PM) [snapback]400020[/snapback]</div>
    What are those wheels
  10. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Here it is with the Scion wheels, (old)
    [attachmentid=6860]
    and the Ray's Gram lights (new). PS- the center caps are on it now- they were on back order.
    [attachmentid=6861]
  11. CheapChic
    40
    <div class='quotetop'>QUOTE(cairo94507 @ Mar 12 2007, 06:46 PM) [snapback]404407[/snapback]</div>
    Looks really good.
  12. cireecnop1
    338
    Pueblo, CO
    Those are nice! but I think I liked the Scion wheels a little better.
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 13 2007, 04:14 PM) [snapback]405044[/snapback]</div>
    I would too but the weight difference is terrible. :(
  14. saisai
    saisai New Member
    Congratulations to you all from France
    I'll post those days pictures of my prius I whith 16 momo wheels
