Please tell me it might not be head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 80sguy, Oct 5, 2025 at 11:22 AM.
  1. 80sguy
    80sguy Junior Member
    28
    Rome NY
    Hello fellow Prius-ers
    My 2013 Prius has a problem.
    I pulled over and stopped for a fire truck and when I went to go again it started doing a shutter from the engine. Lasted only a second or two. I checked the fluids nothing seemed wrong. I was thinking maybe plugs or coils because I don't know when they've been changed. Did it again later that day CEL came on and got a missfire code.
    I made an appointment with the shop for 3 days from then. CEL went out on its own (I didn't clear it) but the day before I was to bring to the shop it did it when I started up cold. And CEL came back on. Friday on the way to the shop the red temperature light flash for about 4 seconds and then went off (literally a half mile from the shop) . I pulled over and checked the fluid level, it was low in the reservoir. I don't know what test he did but he said it wasn't the head gasket. It was Friday afternoon when he got to it and that's as far as he got. I must admit Ive owned the car for around 50k and have never cleaned the EGR. Is it possible that cleaning that will fix the problem or is it a guaranteed HG. Hoping for a miracle here
    Thanks
  2. hurricos
    hurricos Junior Member
    48
    Burlington, Vermont
    Cleaning the EGR at this point won't do anything; if you already have cold start rattles you already have water.
    If you want to convince yourself, park the car somewhere you can work on it and let it cool, a day before you have spare time -- pull the spark plug from cylinder #1 and use a cheap borescope to look inside.
    Not all shops are the same; some will insist that a combustion gas test is enough of a test to determine whether the HG is any good. What usually happens to the Gen3-ECU-managed 2ZR-FXE is that loss of sealing due to thermal cycling lead to coolant entering the cylinders after the engine cools off, and this creates accelerated wear through:
    - the creation of preferred channels for water to flow
    - the loss of coolant, generating more hot-spots (you've seen this with your overtemp event)
    - the presence of incompressible fluid in the combustion chamber. Eventually, you'll get unlucky, and enough fluid will enter the combustion chamber after a cooling cycle to destroy a piston.
    Think about it like this:
    - You have a cold-start rattle (something other than air is making its way to the combustion chamber after the car cools overnight)
    - You are losing coolant somehow
    - You had a known overtemp event in an engine well-known for responding poorly when it overheats.
    Getting it taken care of is cheaper than buying another car, but you probably need to find a shop that works on these engines, because (given the overtemp event) you probably have a slightly warped head they need to check.
  3. BiomedO1
    BiomedO1 Senior Member
    3,177
    1,686
    SacTown, Ca
    OK; I'll bite - It's not the head gasket.
    After the mechanic has bent-you-over for the small repairs that isn't going to solve your problems - he'll hit you with the head gasket repair or whole engine replacement.
    1. few hundred for spark plugs
    2. few hundred for ignition coils.
    3. few hundred for fuel injector
    4. few hundred to clean and/or replace the throttle body and MAF
    5. maybe replace the fuel pump, water pump, O2 sensor.
    After all that; they'll probably condemn the engine and tell you that you need a new one - because they're not going to take the chance that a simple head gasket replacement will fix it! After all the money you've already sunk into it.
    NOW that's a profitable shop....... That was sarcasm; but those gen3 are notorious for blowing head gaskets. How many miles on her?
    Seriously; take the car to an honest Prius specialty shop. A compression, leak-down and chemical test of the coolant for exhaust gases needs to be performed with the engine COLD. Hope doesn't change the outcome of the facts, but you can waste a lot of money in pursuit of a wishful outcome.
    Good Luck.
    FWIW; These cars don't store engine over-heat in the electronic logs. Your temperature lamp turns on around 248F; your normal engine operating temp. is 185F-210F max. - so that intermittent temp. lamp flashing is a BIG deal and your running your engine HOT; which causes blown head gaskets and warped engine parts. I don't know if the car buzzes when that lamp flashes, but it could be flashing a lot and you just haven't noticed it. If coolant levels are low, not touching the temperature sensor, your car will also be running HOT and the lamp will NEVER flash - sensor NOT touching the hot coolant. NONE of the above paragraph is logged by the ECU........
    #3 BiomedO1, Oct 5, 2025 at 1:01 PM
    ASRDogman likes this.
  4. Leadfoot J. McCoalroller
    8,019
    7,496
    Pennsylvania
    2018 Prius c
    Find a mechanic who can do a proper video borescope inspection of the cylinders while the cooling system is pressurized with a test kit.
    That's the quickest, cheapest, real test you can do to verify the status of your head gasket. They're either going to get video of pink coolant dribbling into one or more cylinders, or they aren't.
    Brian1954 and BiomedO1 like this.
  5. bisco
    51,567
    how many miles on her?
  6. BiomedO1
    3,177
    1,686
    SacTown, Ca
    Engine needs to be cool to cold too. Early head gasket failures can seal itself up as engine warms up and the aluminum expands.
    YMMV
  7. PriusCamper
    PriusCamper Senior Member
    12,384
    5,020
    Pacific Northwest, USA
    You can have identical symptoms as head gasket failure and have it not be a head gasket failure if the misfire codes are on cylinder 3 & 4, rather than cylinder 1 & 2. If you're lucky enough for that to happen, it's usually easily repaired in less than a couple hours with new spark plugs and coils...
  8. rjparker
    rjparker Tu Humilde Sirviente
    9,901
    6,105
    Texas Hill Country
    No other misfire causes loss of coolant. Most shops run a combustion gas test and it passes on these engines even with a confirmed hg leak. Your question should be a hg repair or replacement engine.
    80sguy likes this.
  9. 80sguy
    28
    Rome NY
    I remember now what he said. He did some kind of test where some liquid is supposed to change color or not supposed to change color.
  10. 80sguy
    28
    Rome NY
    Thanks for your reply. That makes a lot of sense what you said about the wool coolant not hitting me sensor. And by the way the shop is nothing like what you described I know they're out there but this one isn't one.
  11. 80sguy
    28
    Rome NY
    Sorry I thought I put that in but I guess not. 258K
  12. 80sguy
    28
    Rome NY
    It initially was cylinder two
    He told me it was two also but then four came on
  13. 80sguy
    28
    Rome NY
    Probably no chance that a gasket seal like KCL will get me through to the end of the year will it?
  14. rjparker
    9,901
    6,105
    Texas Hill Country
    Maybe it buys you a month or two... but you are risking your heater core and radiator.
  15. 80sguy
    28
    Rome NY
    Just to get me to January
  16. ASRDogman
    ASRDogman Senior Member
    7,453
    3,874
    DO NOT PUT ANY PRETEND SEALER IN THE COOLANT, OR ANYWHERE ELSE.
    IT DOES NOT WORK!
    It will only give you a fake sense of security. And add the cost of a heater core, radiator, water pump(which
    you likely already need because it's failing or has failed).
    Plus all the little coolant lines, and blocking off the coolant passages in the head and block.
    If you keep driving it, the engine will overheat, more often, and then you'll add the cost of another engine.
    If you read over "head gasket failures" on here, you'll find a LOT of information about them, and the
    cost of not taking care of it sooner.
    And find a shop that specialized in the Prius, or at least works on them and KNOWS about them.
  17. PriusCamper
    12,384
    5,020
    You can keep driving it. Some people go a year or more with occasional symptoms. But once the engine is running rough all of the time you'll destroy your transmission dampener... Also there's always a risk of getting a bent piston rod if too much coolant steams into cylinder one or two when you turn the engine off. aka: hydro-locked.
