pls help ._. 2005 prius with check engine light and p0420, c1378, c1300,c1242 and c1241
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 4EST., Apr 23, 2021.
  1. 4EST.
    4EST. New Member
    MA
    hello everyone i just got my first car... 2005 prius pkg6 with 174,488 miles... i got it and had to do a few minor repirs
    frount bearings
    fround roaters
    fround brakes
    12v battery
    oil/filter change
    02 censor replacement
    ... nothing too out of the ordinary but i drove about 50 ish miles and i got these 5 codes
    p0420
    c1378
    c1300
    c1242
    c1241
    each has a short description of the code but it really doesnt explain too much as to what the issue is and im not sure how to go about fixing each one... i was planning on going to toyota for an estimate but im terriffied ill have to shell out a bunch of money... i see people with the 0420 code saying oil burners cause the issue but i dont know if my car is an oilburner because ive driven a total of under 600 miles (500 ish with the codes and check engine light...) any info or ideas would be so greatly appreciated
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    First thing to do is to provide basic information and data such as what are the symptoms and problems you are experiencing? Does it drive normally? Brake normally? Go to Ready normally? I would then list the codes and descriptions rather than asking us to look it up, especially if you have already done so. I would then provide steps and tests that you already tried. Like what is the 12v reading, both car Off and in Ready? Have you cleared the codes since you did the work on the 12v battery, front rotors and O2 sensor?
    Adding data and background may get you an educated guess versus a wild guess.
    Also realize as a brand new member, your responses may take time to show up since a moderator has to approve them first.
    #2 rjparker, Apr 23, 2021
  3. ChapmanF
    17,349
    I agree with the OP, those short descriptions are barely worth bothering with anyway; there's a reason they get called fortune cookies around here.
    The place you really want to look up codes when you have them is in the Repair Manual (more info), where there will be a full section on each code to explain what it tells you, what conditions cause it to be set, and steps you can follow to find out why that happened.
    Except for the P0420, which may mean the catalytic converter is old and tired (but could also be worth checking the air/fuel ratio and oxygen sensors, or the possibility of exhaust leaks), the other four codes are all brake-system related.
    The C1378 is a problem communicating with the brake backup power supply, which is the odd black box in the back of the car next to the 12 volt battery. The C1241 also involves getting or not getting power from that backup box (you can read more about C1241 here; just don't worry about the other codes in that post that you don't have). C1242 is also a (slightly different) power-to-the-brake-ECU code.
    Your brake ECU is essentially two computers in one box, "system 1" and "system 2", and they have power supplied to them from different circuits, and they check on each other. The C124{1,2} codes involve them noticing when they should both be getting or not getting power at the same time, but aren't.
    The C1300 is a more generic brake ECU mistrusting itself code.
    Two things immediately come to mind. You've recently done the 12 volt battery; you should also check its voltage, in case it wasn't fully charged when put in, or may have drained some since. What the 'x' is in 12.x isn't where you need to worry; the Repair Manual will always have you check quickly that it's not below 10 or 11, and give it a good full charge if it is (which means it'll be 12.x when you're done).
    The other thing to check is that capacitor box back there next to the battery. That can often get disturbed during 12 volt battery replacement, and its wiring connectors don't always get re-seated completely and securely, and that could turn out to be a lot of the story here.
    If you get the battery well charged and you've double checked all the capacitor-box connections, it would be reasonable to clear the codes and see what comes back.
    JohnPrius3005 likes this.
  4. 4EST.
    4EST. New Member
    MA
    okay ill have to check my voltage in the am but i honestly cant tell a diffrence in the car... driving wise, it starts up like normal but evry here and there ill hear what i think is the synergy drive being a little loud when breaking/ speeding up but i cant tell if thats just the car...
    when i got all the work done i had no codes and about 30 or so miles i got a check engine light with the 5 codes listed... i appreciate everyones feedback greatly and for putting up with my ignorance to how this chat works... but like i said it drives fine i still get the same mpg's the only strange thing is really the noise of the synergy drive and when i turn off the car i hear a wirring noise? maybe its the synergy drive turning itself off? but let me check what my voltage readings are;
  5. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    ... including the bolts that connect it to the floor. Especially if you (or someone else at some point) removed that box (which you don't need to) when you changed the 12V battery.
  6. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    yeah .. 1 of the 1st things that goes is the 12v battery .. people dont discon and the computers eat it down ... sometimes they dont recover if enuf time has gone buy..
    the break accumulator .. that thing is a pain .. u can get a used one .. often the pump motor has worn out .. the replacement one i have is from a bit newer car (newer rev number) .. 1st time swap was a real learning curve ... u better have a good back for all the bending over in the engine compartment .. then get yourself a mityvac vaccuum break bleeder ... mine leaks about a pint every 3 weeks ... to me that is liveable because its only about 8 times in 12 months if the car is taking heavy breaking .. if your route is highway even less ...
  7. ChapmanF
    17,349
    OP hasn't got any codes implicating the pump. They're all about electrical supply to the brake ECU (plus the one that's about the exhaust system).
    For the OP, it's never very interesting to say "these warning lights are on but the car still drives OK". That's when you're supposed to get them. If it wasn't, they wouldn't be warnings.
    Prii do make a number of interesting sounds. It never hurts to get used to them and learn what each one is, and be able to notice significant changes. For most people, that takes a while of owning the car, and being sort of intentional about learning what the different sounds are, in advance of any immediate concerns.
    #7 ChapmanF, Apr 24, 2021
    chronon and JohnPrius3005 like this.
  8. chronon
    601
    106
    u learn real fast that the little motor noise humming when u open the door .. is the break accumulator pump , after u get the break code pressure low warning light and or the continuous tone and soft spongy pedal ...
  9. 4EST.
    4EST. New Member
    MA
    so im not sure if i did this 100
    so i did end up checking my battery and im not100% sure i did all the steps i was supposed to but heres how it went
    car off, foot -off- the break hit power--got into that special menu and found my battery voltage... it read 12.6 but after a few seconds it dipped down to 12.4 then i think 12.3 then back up to 12.6...
    staying in that screen i put my foot on the break hit start and it read 11.8 for not even a second then right back up to 12.6 then 12.4 and then 12.3 then back up to 12.6
    then i just was a little confused and now here i am
  10. ChapmanF
    17,349
    So you can check that off the list, and proceed with diagnosing the issues being reported.
  11. 4EST.
    4EST. New Member
    MA
    so next would be my sensors right
  12. ChapmanF
    17,349
    I wouldn't put very much effort into second-guessing the repair manual. The steps you find there for working up the trouble codes that you have are probably as good a guide as you're going to find on the way to pinning down your issue.
    They'll be mostly electrical tests of power-supply circuits, judging by the codes discussed in post #3.
  13. dolj
    dolj Senior Member
    8,217
    4,187
    I'd focus on the C1378.
    DTC | C1378 (Blink Code 44) | Capacitor Communication Malfunction
    DESCRIPTION
    The brake control power supply assembly (capacitor) provides auxiliary power for brake control when an auxiliary battery (12 V) voltage drops.
    The FAIL and ENA lines are placed between the skid control ECU and the brake control power supply assembly. Signals indicating that the brake control power supply is in auxiliary mode are sent to the skid control ECU through the FAIL line.
    Charge permit prohibition signals are sent to the brake control power supply through the ENA line.
    DTC Detection Condition
    When either condition below is met:
    • Open or short in FAIL line
    • Malfunction inside the power back up unit
    Trouble Areas
    • Harness and connector
    • Skid control ECU
    If you are the DIY type, I'd further suggest you get a hold of the repair manual pages (see post #3 for more info) for this particular DTC and work through the full troubleshooting work up in the manual.
    It is all about checking plugs and harnesses looking for a break in a wire or poor connection in a plug. If all checks out those areas then the brake control power supply assembly is suspect. If that checks out then the skid ECU is suspect.
    You might find this post useful.
    Good luck.
    Danny S likes this.
  14. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    That is not normal. After holding the brake pedal and pushing the start button, the voltage should fluctuate for a few seconds, as you described, but then it should go up to over 13 Volts. When you fully start the car with the brake pedal depressed (ready mode), after a couple clicking sounds from the high voltage battery relays in the rear of the car, the DC/DC converter should raise the voltage in order to recharge the 12V battery.
    Maybe you didn't press the brake pedal hard enough while pushing the start button, and the system did not actually go into ready mode. I suggest you try again, and make sure that it actually starts up in "ready" mode. The "ready" light should light up on the dashboard, and the gasoline engine should start after about ten seconds.
  15. 4EST.
    4EST. New Member
    MA
    Now that you say that i actually recall it going to 14v at one point and i was really Confused
    #15 4EST., Apr 26, 2021
  16. ChapmanF
    17,349
    Yes, that's what's supposed to happen. I think I was so used to that being what happens I didn't even notice that you hadn't said it! :)
    4EST. likes this.
  17. 4EST.
    4EST. New Member
    MA
    update i went to toyota and i found out my braking codes were from when i got my brakes and roaters worked on? (I don’t know if that really makes sense because I’d think they would’ve cleared all my codes after my oil change) but the P0420 was indeed my catalytic conver and it’s on its way out... I’m not sure if i should get a new one because apparently they run 2k?? But i was considered doing a seafoam treatment but idk if that’s good on hybrids or would even help but i ended having to fix my struts/springs and that was 1k... any info would help thanks everyone for helping i greatly appreciate each and everyone of you
