Plug and PLay LED interior lights.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by eco-icon, Aug 30, 2012.
  1. eco-icon
    eco-icon Junior Member
    137
    do you guys recommend it? any particular brand?
  2. VegasPrius2010
    VegasPrius2010 Junior Member
    82
    26
    Yokohama-shi, Kanagawa, Japan
    just find a kit on ebay. it's super easy. brand name isn't really a factor. they all probably come from the same factory in China anyway.
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I bought small panels from eBay and made my own - took no time at all, and was only about $20.
    Like this and this.
    I'm not sure how long mine have been in, but it's bright as a football stadium at night, and I've had no problems. I did solder multiple units for the map lights and center dome light. But, the $20 also includes the vanity mirror lights, trunk light, and door puddle lights.
    I think there's a total of 204 LEDs
  4. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    exledusa is really nice, they interior map lights are adjustable.
  5. PriusCamper
    PriusCamper Senior Member
    11,089
    4,512
    Pacific Northwest, USA
    Interesting... Can you give us more details? What do you mean when you say "panels" What does that have to do with lights?
    Also how long did it take to convert everything?
    How much further do you have to go?
    What are the biggest challenges?
    How do you decide what wattage/amperage LED to replace each incandescent with?
  6. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Honestly, cheap LEDs from ebay are good enough if theyre just for the interior.
  7. eco-icon
    137
  8. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    That works. Just know that it doesn't include the vanity lights.
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I initially tried the same map lights (as seen in the video), but wasn't happy with them - not bright enough, and went to 2 12-SMD panels on each side. I use those LED map lights fro my license plate.
    The 6-SMD festoon bulb for the dome light might not have the same brightness as the 2 48-SMD units is used (96 LEDs in the dome light)
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
  11. Fyrod
    Fyrod New Member
    Even I like these LED lights they are efficient and save a lots of money
  12. eco-icon
    137
    thanks for the tip
  13. Bye_G37
    Bye_G37 New Member
    Austin
    has anyone noticed any difference in the range or response of the key fob after this LED conversion? I added a LED dome to my 4runner and noticed that when the dome was set to "auto" my fob range diminished and it took several clicks to get all doors to unlock- when i set the dome to "off" the problem went away - i have no idea how one could be related to the other but it didn't take long after i swapped the dome to notice the difference in fob performance, and sure enough, when i turned off the dome the problem went away (i could unlock my truck from a block away). Just curious if anyone has experienced anything like this. thanks.
