Plug-in **Backseat Teardown** Pics
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RightOnTime, Jun 26, 2014.
  1. RightOnTime
    RightOnTime Senior Member
    768
    1,640
    183
    Kidnapped in OC, CA
    Thought i share some pics of the Battery Assembly.
    Just like the old saying "Out of sight out of mind"
  2. El Dobro
    El Dobro A Member
    7,075
    3,258
    Whatcha' doing back there?
  3. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  4. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  5. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  6. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  7. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  8. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
  9. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Oh neat, duel exhaust fans with what looks to be the intake plumbed from the outside. I bet charging temps won't get much above ambient temps with that set up. Good to know.
    Did you happen to see a part number on the case? I'm curious what chemistry the cells are.
    RightOnTime likes this.
  10. El Dobro
    El Dobro A Member
    7,075
    3,258
    Here you go.
    roflwaffle and RightOnTime like this.
  11. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
    From the 2 days that i drove around town, you can really notice many noises, clicks and odd sounds that is normally absorbed by the interior parts.
    Freeway driving was unique, because you can hear the gravel being knocked around from under the car.
    As of today, all interior parts are back on and there is such a night and day difference!
  12. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Checking for Pandas.
    DadofHedgehog and RightOnTime like this.
  13. El Dobro
    El Dobro A Member
    7,075
    3,258
    That sounds un-bear-able.
  14. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    The fans suck air from the back seat vents and blow it out that black rubber tube in the back, yes?
    I can't feel which way the air is moving when putting my hand near either of the vents.
  15. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Any help on removing the rear seat squab (the bit you sit on) I just can't see how to do it at all.
  16. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Isn't the lift back battery under the back seat? So why doesn't the PIP use this space?
  17. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    If I were you with all these stuff off... I would put in extra noise dampening... ;)
  18. El Dobro
    El Dobro A Member
    7,075
    3,258
    It's behind the seat.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    No pics of individual cells? :D
  20. El Dobro
    El Dobro A Member
    7,075
    3,258
