Plug-in Bookmarks
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Three60guy, Sep 9, 2012.
  1. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    Ever since June, when we purchased our Prius Plug-in, I have been collecting web site bookmarks. I have gained a few and thought it might be useful to share them.
    You need to do just one thing after you download it to your computer. (assuming you can see extensions on your documents (ie test.txt .txt means it is a text file). You will need to change the .txt extension to .html. Once you do that you simply double click on that file and your web browser will show you the list of bookmarks.
    An easier way maybe is when your download window is open just change the extension name from Plug in Bookmarks.txt to Plug in Bookmarks.html. That way it will save it on your computer in the correct format. Then just open that file and you have the bookmarks.
    Edit: For others who are using phones etc I am experimenting with another way of delivery. It's dropbox. If interested in trying it please click on the following link:
    Bookmarks
    Hope you find it useful.
    Cheers
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    nope, don't find it useful, of the options available .txt and all files, no HTML
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Tried to convert on my phone, webpage cant be found when i use html editor
    LG-MS910 ? 2
  4. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Just paste the links here, much easier for us...
  5. Three60guy
    918
    16
    Racine, Wisconsin
    I wish I could paste the links. I tried that. The list apparently is bigger than Priuschat will accept. I got a time out error when I tried that.
    Also, Priuschat would not accept a HTML file to upload. So, that is why I uploaded a text file version which, on a Windows computer would easily be changed to a HTML file by merely changing the extension from .txt to .html. Did anyone try it on a windows computer? This wasn't meant to be used on a phone.
  6. Three60guy
    918
    16
    Racine, Wisconsin
    Did you save it to your computer? Did you find it? If so, merely change the extension from .txt to .html. Double click on it and away you go.
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Worked for me. Just Saved as .html like you said.
    Thanks Three60guy
  8. Three60guy
    918
    16
    Racine, Wisconsin
    You're welcome. Hope you find the links at least interesting. I just wish I had thought through the potential issues this idea would create. I never thought someone would try to do this on a phone, for example. Next time I will put more thought into it.
  9. Three60guy
    918
    16
    Racine, Wisconsin
    The revised additional link on the first post now appears to work on phones etc.
  10. pluginpriusowner2012
    Thanks for sharing this...
