Plug-in hybrids with removable batteries
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Wiyosaya, May 12, 2008.
  1. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
    Full article
    Thanks to this site.
  2. daniel
    14,487
    1,519
    Spokane, WA
    I am so totally not interested in having to change out the batteries to charge my car. Right now, I plug in my Xebra when I park it in my garage and unplug it when I want to go somewhere. The infrastructure cost of maintaining battery-changing stations all along the highway will be much higher than just having fast-charging batteries, which are already available!
  3. hill
    8,640
    But daniel, I think the point is, that if you DO have to drive beyond the car's normal max range, it would be a GOOD thing, to have swapable racks along the way. Who doesn't like the convenience of swaping out their camera battery, or notebook PC battery. Same thing. Or look at CNG cars ... great you can fill at home, but also great you can fill out on the road.
  4. daniel
    14,487
    1,519
    Spokane, WA
    Yeah, but my camera battery does not weigh 500 pounds. And the point is that the new A123 LiFePO4 batteries can be charged in ten minutes if you have a sufficiently high-amperage charger.
    Either way, at home you plug in overnight. On the road here are the proposals, theirs and the sensible one:
    Theirs: Equip a hundred thousand nation-wide recharging stations with as many spare batteries as the number of customers they might see in a day, and an equal number of slow chargers, and several battery lifters to do the actual switch-out. Plus a significant amount of labor to switch the batteries, or heavy, expensive, and complex automated battery changers capable of automatically removing the battery pack, installing it into a charger, then taking another from a charger and installing it in the car.
    Sensible: Install A123 batteries in the cars, and use fast-charging at the recharging stations, equipped with idiot-proof plugs (contact must be established and isolated before current can flow) for self-service charging.
    It should be obvious that the investment in the first proposal is astronomical. Both require the delivery of a lot more electricity than we now have the infrastructure for, but both proposals require the same amount of delivered electric energy. So the big difference is the astronomical investment in additional batteries and the muscle men or the robots to do the switching.
    Further, once we have commercially-available ultra-capacitors, the first proposal above will become obsolete and the entire investment in battery-switching robots will be worthless. Under the sensible proposal, the charging stations will require minimal if any alteration as cars switch from chemical batteries to capacitors.
  5. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    272
    Harrisburg, PA
    And swappable batteries means that those without a plug near their car could take advantage of plugin vehicle technology.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    swappable batteries will never work. what happens if your brand new pack gets swapped out for a worn out pack and the pack dies? do you get another brand new pack? or do you have to track your battery purchases, go thru a lengthy warantee return process while sitting on the side of the road somewhere?
    oh ya... sounds like a great plan....
    i think i'd rather wait for super caps
  7. bbald123
    386
    272
    Harrisburg, PA
    What? I have swappable packs on many devices. I manage to know SOC on them. Why would a car be any different?
  8. dipper
    dipper Senior Member
    1,242
    252
    You mean you swap packs with strangers and unknown battery quality on your cameras, camcorders, and cellphones?
  9. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    The real answer is to electrify the freeways. Add a couple of metal bands down each lane and then put some brushes on the bottom of the car like a slot car that can pick up the power from the lane and transfer it to the batteries. We can have an electric meter on the car and it can be added to the power use from our home meter.
  10. daniel
    14,487
    1,519
    Spokane, WA
    Which you could do if there were fast-charging stations. But without all the extraneous infrastructure needed to swap thousand-pound battery packs.
    My camera uses a battery that weighs an ounce or so. I think my laptop battery probably weighs what? a couple of pounds? My 2,000 pound Xebra goes 40 miles on a 200-pound battery (lithium). Double the weight of the car and give it 100 miles of range and the battery will weigh a thousand pounds. You want to swap that out like a camera battery?
    You own your camera and laptop batteries. You invest in quality to give you reliability. With swappable car batteries you won't own the battery. And you will have no control over whether they give you a good one or a bad one each time. And they'll charge you for two batteries, because while you're driving they have to have one on the charger. And due to the weight, they'll probably need a robot to swap them, so you'll pay their cost of buying and maintaining the robot. And if the robot goes on the fritz you're likely to find yourself stuck in the swap bay with a battery half in and half out.
    And since batteries today (A123 LiFePO4) are capable of fast charging, all this swapping is totally unnecessary. Unless maybe you plan on using a 5,000-pound lead battery pack instead of lithium. (Patents prevent you from using NiMH due to the size restrictions. So you might as well use LiFePO4, which is better, and then you don't need to swap batteries because they can be fast-charged.)
  11. clett
    clett New Member
    537
    Scotland
    The advantage of the swappable battery idea is that you could buy a very cheap electric vehicle (in the $10,000 range for a Prius size and quality vehicle) without a battery installed.
    Then you simply pay for a fully charged battery to be installed at a 'filling' station, owned by one of the big 'oil' companies. Drop it off at the next filling station of the same company to be replaced with a freshly charged battery.
    The advantage of this setup is that advances in battery technology, especially increased range, will be applied to the car the minute they are available at the filling stations, so no need to change the car, and the 'oil' companies will be falling over themselves trying to offer the best performing, longest range battery to attract your custom. That will lead to some serious competition and improvement in battery technology.
  12. daniel
    14,487
    1,519
    Spokane, WA
    A couple of problems with this: While the initial cost of the car will be lower, you'll be paying an arm and a leg for the depreciation on the batteries every time you swap. And you'll be tied to a single oil company (you're probably right in hinting it will be oil companies running the battery-leasing operation). Let's say you want to switch companies. You'll have to pay someone to tow your car from your old station, where you dropped off the battery, to the new station. And BTW I guarantee they'll charge you not only for the amount of charge you used, but also for the time you had the battery, since that represents a cost to them in the form of capital inventory.
    Tom & Ray of Car Talk like to point out that "It's the stingy man who pays the most." In opting for the cheaper (no-battery-included) car, your lifetime operating cost will be significantly higher, because the motoring public collectively must pay for all those batteries, including the ones being charged and not actually in a vehicle plus an additional profit to the oil company for leasing the batteries to you plus the capital and labor costs associated with physically switching the batteries. Note that this system requires significantly more batteries because fleet-wide every car has a battery in it while at the same time the off-duty batteries are being charged so as to be ready each time a car pulls in to the station.
    Since batteries have a much shorter range than gas tanks, it is not unreasonable to assume that the average car will pull into the station once every day or two. If it takes a day to charge the batteries, the number of batteries fleet-wide will have to be roughly double the number of cars, and this represents a huge capital cost, which the oil companies will pass along to the motorists in the form of battery-switching cost.
    Finally, while newer battery technology will be brought on-line rapidly, the motorist will pay for this rapid upgrading. The oil companies will not lose money. That means the motorist will be forced to pay for those newer batteries whether he wants to or not. With your own battery in your car, you decide whether or not to pay for an improved battery. (Though perhaps the battery stations will offer a selection from cheaper shorter-range batteries to more expensive longer-range ones.)
    With fast-charging batteries available now, it just makes more sense to use fast-charging of permanently-installed batteries. It's simpler, cheaper to implement, and requires significantly less total investment.
  13. clett
    clett New Member
    537
    Scotland
    Fair point.... Altair nano all the way then! :)
