Plug-in # of batteries
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by syscon, May 7, 2012.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does plug-in has 3-batteires?
    Standard 12V
    Lithium-ion pack 4.4kWh (rechargeable from a power outlet)
    And another battery like a standard Prius when 4.4kWh pack is depleted it uses standard ICE + standard Prius battery (non rechargeable from power outlet).
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    No. It's a single battery with 2 sub-packs, but both can be used.
    In the pre-production model it had the standard NiMH plus 2 lithium sub-packs which it could use alternately until a sub-pack was exhausted.
  3. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    The 4.4kWh Prius PHV battery is a single battery composed of 4 modules in series.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'm not sure about the 2 (or 3) sub-packs anymore on the production PiP.
    The pre-production PHV had 3 packs, but all 3 were li-ion, AFAIK.
    See https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/priusphv.pdf from https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti;TISESSIONID=FLhjPyWYGvF7vNBDph7JPvLsLp5JG4zTLZy3t6hHDv1plnGTgmVG!1488617632?_pageLabel=ti_erg&_nfpb=true (the 2nd URL might not work, so go to techinfo.toyota.com/public/main/erg.html and then Emergency Reponse at the bottom).
  5. jbrad4
    474
    148
    Rowlett, TX
    Go to this thread. This has already been hashed and re-hashed.
    The Prius PHV has a single battery with 4 modules in series.
  6. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Thanks folks. I was reading somewhere that it had 3-batteries but it must have been per-production version.
