Plug-in Prius...whats the point.?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Microamps, Jan 14, 2006.
  1. Microamps
    Microamps New Member
    17
    Melbourne, Australia
    Ok so the maximum speed in EV mode is 34mph, we know that. So why are people bothering to add battery capacity to a prius?
    I understand that it increases the range under electric power but that range can only be driven at a max speed of 34 !!
    That doesnt seem that practical to me, or is there something I'm missing here?
    I dont mean to be rude or ignorant, infact in principle I think its a great idea, if the speed were more useable.
    I would assume most people commute at speeds higher than 34. Whilst I can see the benefits in built up areas and city driving........ but on open roads - even on main roads, the speed needed will likely be higher than 34mph.
    May as well be adding batteries to grandpas mobility scooter.
    Or are they increasing the EV speed capability of the 'plug-in' cars?
    Thoughts from those in the know would be appreciated.
    uA
  2. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Hi MicroAmps,
    I am unfamiliar with units used down under, so forgive my use of US units.
    The Prius' max EV speed is about 43 mph. The EV Prius speed limit does not have anything to due with maximum battery power output, but rather is a transmission limit to protect one of the electric motor/generators from spinning too fast. But Prius speed of course goes up to about 100 mph, which is where your analogy with grandpa's scooter goes awry.
    At higher power output demands, nothing prevents you from using your battery's power; it is just supplemented by the ICE as needed, and less ICE is required this way.
    The holy grail is more capacity. Higher battery power would be nice, but good enough as it is in the current Prius -- about 20 KW.
    ICE: Internal Combustion Engine
  3. bobr1
    bobr1 New Member
    306
    Portland, Oregon, USA
    Hi Microamps -
    The point of a "plug-in" Prius is that the electric motor can augment the ICE at a wide range of speeds. It is just that under 35mph, the car is capable of running purely on electric power.
    Even if you drive a lot of highway miles, the electric motor helps for acceleration. For city driving with a lot of stop-and-go and stretches under 50mph, having extra battery power can help even more. That is why people are experimenting with larger batteries in the Prius which can plug-in to recharge.
    Today, I had to take several small trips at different times: To the bank, to the post office, to the store. (These trips couldve been linked with brain usage, but the brain wasn't working full-time today.) The majority of this time was spent on local streets at under 35mph.
    A plug-in Prius would've worked great in my case, because little or no gasoline would have been consumed, and the batteries would be recharged off the grid when I got home at a cost considerably less than gas.
    While these early experiments are very encouraging, batteries need to get cheaper and smaller (for the same power output) in order to become a really practical production item.
    - Bob R.
  4. EricGo
    EricGo New Member
    1,805
    Bob,
    I find it useful to think of a PHEV just the opposite: The ICE can augment the batteries.
  5. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Basically, you're right; the usefulness is limited. I've heard folks say it's mainly useful for short-hop errand-running, where you don't want to use the ICE in its least efficient mode for, say, under 10 minutes, just to run down to the store.
  6. Microamps
    17
    Ok, I understand how the PSD splits and limits the revs accross the ICE, MG1 & 2 and that the battery becomes only an auxiliary power supply once the cars speed is over the magic 34mph mark, and that under that point batterys can be the primary source of power. That part is no different from the current situation with its 6Ahr NiMh battery.
    My analogy with granpas mobility scooter was an exageration but you get my point.
    It just seems to me to be a shame that although the Prius is able to be powered totally electrically up to 43mph, it is not fully utilized as an electric vehicle by only allowing the driver 34mph as an electric maximum.
    Is there any way of optimizing the EV function so that short bursts over 34 will not fire up the ICE, raising the limit, so to speak? Its probably a hybrid ECU control limitation requiring reprogramming (I'm guessing here) and a safety control to stop MG2 overrevving (guessing again)
    uA
    P.S. nice sig line jack-06 :)
  7. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    You are basically under the impression that the electric motor is only used in EV mode, at city speeds. That isn't actually the case.
    Just watch the Energy Monitor while cruising down the highway when the charge-level is in the green. You'll be quite surprised at just how much electric motor contributes. MPG is higher than usual during that time. Now just imagine what the effect would be with a much higher capacity battery-pack charged via a plug. Highway efficiency would be remarkably impressive.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    considering the much higher conversion and efficiency ratings of line power, its much greater potential to generate cleaner power, and the ample opportunities to recharge, i think an extended range hybrid that only uses gasoline as a backup instead of the primary source of power is a no brainer and inevitable.
    we have only lately realized that battery technology can be greatly improved and instead of yesterday's notions of not even trying for better EV vehicles because of limited range and weight/space issues, there is actually measurable progress on the road right now.
  9. Microamps
    17
    John, I do understand that the motors run in unison (synergistically),and that the electric 'boost' contributed at higher speed is considerable, what I would like to work towards is having the electric motor run alone more often, at a wider range of speeds.
    Even if the ICE was used during acceleration to just under its present max of 43mph then switching back to EV only
    I am being a little hypothetical here, and I know the current capacity of the NiMh batterys wont allow much range at this speed.
    If you could take extra onboard battery capacity as a given (lets say for this example you have 100Ahr) would a higher 'EV only' speed be advantageous in the day to day running of the car? I think it would.
    uA
  10. EricGo
    EricGo New Member
    1,805
    I guess my first post was unclear.
    If you have X Kwh of battery capacity charged from the grid, it will displace petrol use for an equivalent energy amount.
    Sometimes in EV only mode, sometimes in conjunction with the ICE.
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    we kinda have two threads going on nearly the same thing, so i will repeat. if we had a Prius that could go 20-30 miles on 100% EV power, even if it only worked at 40 mph or less, it would be a huge increase in performance.
    our mileage is killed because of low speed driving. stops and starts kills us. hybrids only partially address those issues. even under the best of circumstances, we are lucky to be in EV mode 50% of the time. imagine if it was 100% for the first 20 miles every day. and all we needed to insure that range was 4-6 hours of plug time.
    rumor has it that Toyota will intro a hybrid with Lith power in '08. give me an upgrade option of at least 20 miles EV and im in...
  12. EricGo
    EricGo New Member
    1,805
    There are two considerations playing out here.
    One is energy use, and where it is from
    Two is ICE efficiency
    If the comparison is between a Prius and a PHEV-Prius, both will have very efficient ICE use. Wayne Brown has added extra capacity to his Prius but does not plug it in as far as I know, and reports improved fuel economy. If he lives in a hilly area I can understand the improvement, but I think it fair to say that for most people the differences will be mild. In city driving, energy lost in braking will be the same. On the highway, energy used to overcome air resistance will be the same.
    The real advantage is simply displacement of petrol by grid electricity. Pure EV or combined EV/ICE does not really matter. Worse case scenario with a driver who knows what they are doing: short bursts of ICE during accelerations (offset by 20 kW motor input) and 0.2 gallons gas/hour at speeds greater than 43 mph, up to speeds requiring less than 20 kW.
    IT WOULD BE FANTASTIC
  13. KMO
    KMO Senior Member
    1,541
    425
    Finland
    2023 Prius Prime
    The car can, and will, run on electric-only up to 42mph. It normally doesn't, because it doesn't have that much battery capacity, and doesn't want to drain it. But if a plug-in conversion can persuade the system that it's got plenty of spare battery charge, and should be bleeding it off, then it will very much favour electric-running.
    If you've ever reached 8 bars, then you will have seen that the car behaves quite differently - it will much more readily pull away from a stop without firing up the engine at all, simply because it wants to drain the battery. I'm assuming that a proper plug-in conversion would push the car towards its "8-bar" behaviour - attempting to drain the battery during travel - otherwise there wouldn't be much point; you'd end up at the end of a trip with a still full auxiliary battery!
    And I don't know what your commute is like, but I certainly don't get above 30mph most days of the week.
  14. Microamps
    17
    That makes sense, I havent actually seen my car at 8 bars yet.
    So I suppose if the car has battery capacity added and is modded to see a high state of charge (SOC) then it will be constantly prefering to run on battery power.
    Hmmm, food for thought.
    My commute is (in US terms) is two trips of 35 miles (50km to and from work) each. Half of each trip is open road 65 mph (100+kmh) and half is busy stop and go traffic.
    Might have to investigate this idea some more.
  15. EricGo
    EricGo New Member
    1,805
    That is exactly how the CalCars ECU is programmed.
