Plug-ins and flats, what's the course of action?
Discussion in 'Prius PHEV Plug-In Modifications' started by burritos, May 19, 2009.
  1. burritos
    burritos Senior Member
    4,946
    252
    Is waiting for a tow to the nearest tire shop your only option? That is if you decide not to carry the spare in the hatch trunk space?
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I am pretty sure that with the HyMotion plug-in conversion you have to chuck the spare and call the truck.
    This was tossed around here and that was the conclusion.
  3. syncmacd
    syncmacd Waxing is Relaxing
    SoCal
    If you're willing to sacrifice the tire you could carry a cannister of Fix-a-Flat in your car. After you attach it to the tire it inflates the tire and puts out this goo that will fill most small punctures. The tire doesn't inflate all the way but it is good enough to get to the car shop. The downside is that you can't use the tire anymore as it will seal the tire nozzle. Sometimes a tire can be repaired at the autoshop, but not after using the Fix-a-Flat.
    I would recommend jacking the tire up a bit so there's not as much pressure on the tire; even so the tire looked a bit flat at the end.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Since I don't carry around anything or haul stuff I keep my spare strapped down in the back using the straps that came with the car. Works great and I still put stuff on top. My jack and tools are wedged underneath the Hymotion exhaust duct. Thats not recommended but it works.
  5. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    I do what TheForce does. And I carry a can of fix-a-flat.
  6. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    At the moment my spare is underneath my batteries, but when the new battery case is finished I doubt it's going to be possible to lift the batteries out single-handed to get to it...
  7. jstack
    jstack New Member
    211
    38
    Chandler Arizona
    I
    Just wait until the tweel from michelin comes out. It's a tire with no air and can never go flat. There are also run flat tires but I don't think they are as energy efficient. The EV1 used to have run flat tires si it didn't need to carry a spare.
