plugged A/C drain leaks into rear passenger floor?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sean Daniels, May 11, 2016.
  1. Sean Daniels
    Sean Daniels New Member
    I have a 2011 Prius that is collecting water in the rear passenger floor board. I notice that water is no longer leaking from under car when parked after using the A/C. Does anyone know how the drain is routed, or have experienced this?
  2. Mendel Leisk
    38,648
    Not sure of the exact routing, but it's definitely draining near the front, passenger side. I've noticed the exit tube when doing an oil change.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Is the floor plastic plug seated properly? Under the rear seat cushion
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I would pull the passenger carpeting area up and check the A/C routing there. There's plenty of videos on YouTube to show where and how to do it. Good luck.
