Plugin noise and check engine light?
Discussion in 'Gen 3 Prius Main Forum' started by rondocap, Dec 31, 2012.
  1. rondocap
    rondocap Member
    64
    28
    So my 2012 plugin was parked for about 3 days, and when I turned it on, heard loud knocking and the check engine light came and stayed on.
    When switching the car on or off, I'll hear two taps/ticks that were not there before. Loud knocking is not there now.
    What can the issue be? It was very cold and snowing.
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Did you look under the hood for any dead animals that may have taken shelter there?
    Lol, other than that, I hope you don't have a serious mechanical problem.
    49,509
    where are you located? how cold was it?
  4. rondocap
    rondocap Member
    64
    28
    Nj, maybe went down to 20 F?
  5. bisco
    49,509
    i was thinking the 'knock on cold startup', but i don't think that sets the engine light off or leaves permanent sounds. does it drive okay otherwise?
  6. rondocap
    rondocap Member
    64
    28
    Yeah it was ok.
  7. rondocap
    rondocap Member
    64
    28
    What do you think it could be?
  8. rondocap
    rondocap Member
    64
    28
    I checked codes, and got P0301 cyl 1 misfire.
    Is it a on time thing? Or should I not erase the code and bring it to toyota?
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Classic case of the ICE knock. First time I heard of a PIP having the problem. Be sure to report it to your dealer. Did you clear the code?
    Most of us victims never get a code... you did, congratulations. :)
  10. rondocap
    rondocap Member
    64
    28
    I did not clear the code, should I bother taking it in? Or will the car function normally if I clear it and it doesn't come back?
  11. rondocap
    rondocap Member
    64
    28
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh yeah, leave the code and take it in. Yes the 10-11-12s are all having the problems. I had the IM replaced and have not had the knock since but others have since replacement. Apparently it is not a total fix.
  13. rondocap
    rondocap Member
    64
    28
    I drove it longer today until a warm up cycle was completed, and the light went off automatically.
    I think what caused it was moving the car while cold for a few minutes.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The code will remain until cleared. I would still recomend takinh it in and having it documented.
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That is what causes it for most of it.
