Poll on Prius cold-start knock
Discussion in 'Gen 2 Prius Main Forum' started by bwilson4web, Nov 26, 2012.
  1. bwilson4web
    16,012
    I'm not aware of a wide-spread problem with cold-start, engine knock in the 1.5L Prius but we're trying to characterize what it takes to reproduce the 1.8L Prius, cold-start, engine knock. It is intermittent and rare but if we can come up with a protocol that reliably reproduces it, we have a chance of getting effective, corrective action. If you've had the knock, recently, please take the poll and add any additional details including your model year that might lead to reproducing this problem at will:
    Reproducable knock? | PriusChat
    Thanks,
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Very occasionally my 2009 Prius makes loud banging noise when the engine stops at the end of S1 in Park. No apparent pattern.
    bwilson4web likes this.
  3. bwilson4web
    16,012
    Thanks!
    This sounds different than the cold-start problem we're seeing with the 1.8L Prius. But it is interesting, none the less.
    Our 2003 Prius doesn't knock but if I do the following:
    • level side street 45 mph, engine is on
    • shift into "N" and coast down to below 41 mph
    • shift briefly into "D" and back to "N" before engine halts ->
      • I'll hear and slightly feel the engine shudder to a stop, no knock
    In your case, I'm wondering if the 'parking pawl' might be loose. If the car is in "P", do you hear a knock if you try to rock the car back and forth on a flat surface?
    Thanks,
  4. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    You guys are scaring me...lol. My 2007 has never knocked or made any engine noise. Yeah, in the early stages before its fully warmed up it starts and shuts off harsh sometimes but it doesnt make any kind of noise associated with it.
  5. 2009Prius
    2,705
    511
    63
    I tried to rock the car in park in several different locations and no knocking sound at all. And I am pretty sure the noise I heard before came from the engine.
  6. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Bob,
    Just like other Gen 3 owners have reported here, I experienced the cold-start knocking with my 2010 the morning after after shutting down the engine with only a few seconds of run time while moving the car in my driveway. (EV isn't available with a cold engine below about 60 degrees.) Ambient at the time was maybe 30 degrees. The car then sat overnight. Upon start-up the next morning, I got a few seconds of the rough-running routine where the engine felt like it was trying to swap pistons. It's only happened twice in over 2 years with the car, and thanks to PriusChat, I now know to let the car run long enough to turn itself off. I'm not conversant about the several stages of warm-up, but it appears that the Gen 3 doesn't like to be interrupted while in the first stage ("warm-up interruptus"). Whether due to moisture in the intake manifold or confused programming, a start-up in cold weather after a short run time the night before may result in the automotive version of delirium tremens.
  7. 1945steve
    1945steve Junior Member
    68
    southern indiana
  8. EAP
    EAP New Member
    My 2012 had exactly these symptoms yesterday. ~30deg outside, did a quick move of my car in the driveway and shut it off, then had a rough terrible start the next morning. I'll let it complete the startup cycle next time!
  9. bisco
    51,154
    good idea!(y)
  10. slimothy
    slimothy Junior Member
    Seattle, WA
    Sometimes, even 10 minutes of sitting after letting the engine run for a few seconds cold will generate the knock and pending codes.
