Poor Gas Mileage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by darkgiant, Feb 19, 2018.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I am working on a relatives 2005 Prius, and they are experiencing a dilemma where their Prius always has had poor gas mileage (as of right now, in the winter, gets roughly ~28-34 MPGs, summer ~38-40 MPG). The car itself just hit 190K so I volunteered and did a spark plug change, changed the oil (it was time for one anyway), changed the PCV valve (it was really clogged up). After doing this, my friend noted the car definitely feels a lot better, but the gas mileage hasn't improved significantly. Several things they mentioned was they had swapped the hybrid battery at a local shop with a refurbished one, but the warranty just expired. From my general testing, the hybrid battery definitely holds the charge, and when driving around there is no evidence of a bad hybrid battery (I have been in Prius's where the hybrid battery is going bad or is pretty much done, and no evidence of this was visible).
    Several things I did notice though (and this may be the large reason for poor mileage) is that my friend only uses the vehicle for ~ 3-mile commutes to work, thus only putting ~6-10 miles on the car on a daily basis. I figured due to the short commutes, that can be the root cause, but hitting ~28-34 MPGs right now doesn't seem to make sense to me. The tires can be replaced, but I'd say there are at least ~5,000-7,000 miles on them based on the tread, give or take. I also hooked up Techstream and not a single code was found.
    I am basically running out of ideas, and my friend was wondering if they should consider selling the car for something else, and I personally am growing curiosity as to what can be causing unusual MPG's for a vehicle with a hybrid battery that was just replaced, and an engine that doesn't show any evidence of strong amounts of wear and tear.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Bingo! We have a winner.
    A plug-in vehicle that can cover that short range purely in EV mode is the cure. Or just live with the "poor" mileage.
    exstudent likes this.
  3. JC91006
    16,827
    8,600
    The poor mileage is due to the short drive. The car doesn't even get past it's warm up stage
  4. darkgiant
    darkgiant Member
    287
    42
    Seattle
    But those numbers seem unreasonably low. I used to commute daily in my old 2007 (which has long been sold) and I had a stint where I only used the car roughly ~15 miles a day give or take (usually just a 4 mile commute one way to school add on running some errands and what not), and the difference in MPG's was going from ~48-49 to ~44-45. Anything <35 seems pretty low, no?
  5. darkgiant
    darkgiant Member
    287
    42
    Seattle
  6. bisco
    52,372
    a lot goes into poor mileage, and a 13 year old car with 190k is part of it.
    tires, pressure, filters, injectors, throttle body, egr, driving style, etc. you say it has always been poor, has she owned it since new?
  7. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Yes, that seems very low. We know the car struggles under bad driving scenarios for FE....what about an ideal situation? Hasn't anyone tracked that Prius' fuel economy for a longer drive on a warmed up engine on a dry, sunny day?
  8. bisco
    52,372
    great idea!
  9. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Not entirely sure if the issue has always existed, but I recall them bringing this up for the past year. And the car was owned since new, but it was handed down from his parents. But I acknowledge that there is a multitude of variables that go into gas mileage, but figured maybe there is a common thing I can inspect/fix (in this case, I thought maybe a PCV Valve replacing can do it). But even then, I have seen in person 2004s and 2005 Prius's kicking it with 250,000+ miles hitting 45+ MPGs, granted those are being used in different ways then this vehicle, I just don't think age and current mileage would be the sole diagnosis, especially since the hybrid battery and engine both seem to be working perfectly fine.
  10. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Appreciate the sarcasm. :)
  11. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Nope. Those numbers are spot on. Wife currently has a one mile commute to work, one-way. The MFD averages 34-38MPG. Granted, weekends experience some longer drives, which probablly increases the MPG average.
    Ambient air temperature adversely effects MPG too.
    Your relative's Prius is probablly suffering from a discharged 12V battery. This will adversely effect MPG, as the HV Battery charges the 12V battery, and the gas engine recharges the HV Battery. Have them, get a smart 12V charger that is AGM compatible, and frequently top off the 12V battery.
    Is my inverter coolant pump slowly failing? | PriusChat
    Post 5-quick easy way to load test the 12V battery
    Post 8-some smart, AGM compatible, 12V battery chargers. ​
    If they really want to optimize MPG, get an engine block heater. Engine Block Heater for 2004-2009 Toyota Prius - PriusChat Shop
    This will absolutely improve MPG, for obvious reasons: engine will be closer to operating temperature much sooner rather than later. They should get a timer so the block heater turns on for maybe an hour or two before they leave in the morning.
    Tell your relatives to bundle up and not use the heater! This will improve MPG for obvious reasons. The engine wont be running excessively, to maintain hot coolant, for cabin heat.
    If they continually drive short distances, maybe switch to a thinner oil. Maybe 0W-20?
  12. bisco
    52,372
    you probably have a combination of factors. finding one thing (other than the short trips) is unlikely. tires can be a fairly major mpg buster. i would check the pressures and model to see if they ar LRR.
    has anyone reset the trip meter and gone for a 40 mile drive to see what mpg's it returns?
