Poor man's scissors jack power drive adapter
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Georgina Rudkus, Feb 23, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    No need to buy a special adapter for a hook drive crank scissors jack.
    Use a 1/4 hex to half inch drive socket adapter and a proper sized socket. That's all.
    Brian1954 and Mendel Leisk like this.
  2. Mendel Leisk
    40,483
    What size socket did you settle on?
    I liked Honda's style, much more stable:
  3. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    22mm or 7/8 inch
  4. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    I bought one of these adapters, around $12. Works well and I don't have to worry about losing a socket out of my set, or wearing the socket plating off the inside of the socket.
    Drive Scissor Jack Adaptor, 1/2in Scissor Jack Quick Drive for Jacks(28mm (VT17711)) https://a.co/d/dwMRqB3
    SM-G781V ?
  5. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    There's not much wear, if you use the correct sized socket.
    I can always go to the crank handle without using two wrenches to remove a commercial adapter.
    That's $12 I didn't need to spend and saved. I already had the socket.
