Poor Mileage in 2007
Discussion in 'Gen 2 Prius Fuel Economy' started by Rest, Apr 15, 2011.
  1. Rest
    Rest Active Member
    1,210
    53
    CA
    Just completed an 800 mile trip and the highest average I could get was 47 mpg. This was with brand new Michelin Energy Saver tires running 42 psi in the front and 40 psi in the rear. Seems like no matter what mileage tricks I try, nothing improves the average past 47 mpg. This sure is frustrating.
  2. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    From what I understand, the mileage will increase as the tire breaks in.
  3. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    It's easy to forget that the 2007 Prius is only rated 45 mpg on the highway from the EPA when you look at the revised 2008 numbers. You beat the EPA!
    If there's no problem with the car at all, I recently did two big second gen Prius fuel economy posts on my blog. If you scroll down on the right to "Prius mileage tips" under keywords they're currently the first two that will pop up. There's one about Hobbit's style of driving specific to the highway.
    Forgive me if this stuff you already know, I see you have a lot of posts :)
  4. richard schumacher
    7,663
    1,038
    United States
    How fast were you going on that trip? How fast was the wind?
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It is hard to travel 800miles in or through California without hitting some serious elevation changes as well.
    Plus you have brand new tires. They require a break in period so most of your 800 miles would have been part of the break in period thus lower mpg.
    The GenII has no problems getting 48-52mpg on a flat highway and cruising along at 65mph or less.
  6. Rest
    Rest Active Member
    1,210
    53
    CA
    While it's true my new tires need to break in, I also was never able to get better mileage out of my OEM tires. During my recent trip I drove the speed limit of 70mph and yes some parts were on hilly roads. I constantly read where many have been able to average far beyond 47 mpg, yet for some reason I have been unable to best this.
  7. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    If you lowered your speed on the trip your MPG's would increase.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  9. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I see some difference in MPG between 65 and 70 MPH. But still you should generally get little bit more than that, like 50 MPG in hilly conditions (at least that's what I get in my 2006). :( When I change oil, I have noticed that my MPG drops for the first two tanks or so, not sure why.
  10. richard schumacher
    7,663
    1,038
    United States
    There's the problem.
  11. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Rest needs to read Hobbits stuff on 6X mpg at 6X mph. Above about 64 mpg, the Prius cannot drop into warp stealth, and your basically driving the car as if it was a standard car, with the engine always turning over, fuel injecting/burning, and the transmission at a fixed ratio.
    Various people have done prius PSD gearing on-line aps which show this clearly. Look at this link: Toyota Prius - Power Split Device . Set MG2 to a 64 mph. Set Engine to the 1000 RPM - the warp stealth RPM, and you will see that MG1 is spining close to the max negative limit of -6400 rpm. If you up MG2 to 65 mph, that negative MG1 limit is exceeded.
    So, if you travel above 64 mph, the car cannot enter warp stealth, and it continues operating in a engine-on mode. This does not mean you cannot exceed 64 mpg. Going uphill, keeping it around 20 HP in the BSFC mound, no problem if you get over 64. But when you crest, you need to be back down under 64 to get into warp stealth. Otherwise your idling your engine down the hill, for no good reason. Hobbit (and others) report 60 to 65 mpg using this technique.
    Now, this works for hilly terrain. Because in flat terrain at these speeds, you quickly exceed 64 mph at the BSFC mound power levels. And you cannot store energy into vehicle speed, effectively, due to aerodynamic non-linearity. But, in a hilly terrain, you can store energy into vehicle altitude , with the engine at a good BSFC point.
    With Hobbit's technique one drops down to under 64 mph at the crest of a hill and gets into warp stealth. Now the engine is off, but turning over at 1000 rpm, from electricty being generated by MG2, and fed to MG1.
  12. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi Rest. Under the right conditions I can get 60 MPG at speeds around 40 to 50 MPH, but at 70MPH I'm down around 47 MPH also. I'd say you're going ok considering the relatively new tires.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Hi Donee,
    I am probably not following the Hobbit trick ...
    Are you saying the fuel economy advantage is gained from having the ICE turn at a lower rpm some of the time ?
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    Yep, sounds right to me too. I manage about 50 mpg at 70 mph, but the difference is explained by the thinner air where I live.
  15. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Sage,
    Let me start over. The fuel economy is gained by using the engine at optimum BSFC (best efficiency) to store energy in moving the car higher in altitude, then not burning gas downhill. This results in low enough losses to get good mileage. To get the car in warp stealth for the downhill glide, you, when you crest the hill you need to be 64 mph , or less.
    In warp stealth, the car is not burning gas, but the engine is still turning (through electrical power).
  16. SageBrush
    11,627
    2,530
    Southwest Colorado
    Donee,
    I apologize for being dense, are you just pointing out that ICE use downhill is unlikely to be in an efficient range ? That makes sense to me, but how about driving on a flat with constant ICE use ? Any fuel economy lost ?
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Are you being sarcastic? As pointed out, you beat EPA for your vehicle- with brand new tires. 47 mpg, is not "Poor" mileage.
  18. Rest
    Rest Active Member
    1,210
    53
    CA
    Thanks for all the responses, it helped me understand my situation more. I wish for the day when we don't have to drive a car like this in a special way to get great mileage gains.
    I've noticed that even driving my Prius around town on short trips I can't top the 47 mpg average mark. I get segments that far exceed that number but the average always drops it down.
    So, I am beginning to wonder if a Chevy Volt or Nissan Leaf would be more the right vehicle for me. Don't get me wrong I have enjoyed my Prius over the years but it seems that for what I paid, the average mileage would have been much higher without driving it in such a special way. Maybe in my head I'm still thinking about the numbers from my previous car, a 2001 CVT Honda Insight (I know you really can't compare the two vehicles).
    But here we are in the 21st Century and the majority of vehicles still don't average over 50 mpg. The technology is there and has been there for some time. Makes one really hate big oil!
  19. richard schumacher
    7,663
    1,038
    United States
    "The right vehicle for you" depends on the problems you are trying to solve or the needs you are trying to meet. If you want to minimize petroleum consumption, then certainly an EV such as the Leaf is the answer. If you want to minimize global warming, the answer may be something else. Minimize total cost of ownership or operating expenses, something else yet again. What do you want a car to do?
  20. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    When I lived in the SF Bay Area, my lifetime average was ~46 mpg. I did manage an "tank" above 50 mpg by keeping my speed down on the highway below 70 mph, the whole time. When I was newer, I too was wondering if it was me, my driving, California conditions, California gas formulation, etc. I posted at http://priuschat.com/forums/gen-ii-...commute-w-little-opportunity-pulse-drive.html.
    Regarding short trips, that kills mileage. I now live in a much colder climate and now just have almost all short trips. I'm lucky to break 40 mpg on a tank, but this isn't surprising to me at all. (I average only ~13-17 mpg :eek:typically on my Z now whereas I'd get ~21-23.x mpg when I was in the Bay Area.). Most fuel-efficient cars is what CR got on the 2nd gen Prius. Last page of http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf describes their test procedure vs. the old government one.
    I don't know if you ever read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html. It was very insightful.
    As Chevy Volt is only EPA rated 35 city/40 highway, 37 combined in charge sustained mode. As for Honda Leaf, there isn't one. :) There is the Nissan Leaf.
    Since you're in CA, your electricity is likely expensive. You might be curious to see http://priuschat.com/forums/chevrol...olt-in-their-long-term-fleet.html#post1280607. Although you'd end up reducing your use of oil (or making it 0 w/the Leaf), you might both are costlier to drive than a Prius due to high electricity costs.
    As for "But here we are in the 21st Century and the majority of vehicles still don't average over 50 mpg", unfortnately, per Power Search, if you exclude EVs in your search and look for 2010-2011 models w/combined mileage >50 mpg, there are 0. The only one that gets 50 mpg combined on the EPA test is the 3rd gen Prius.
    We definitely have an issue w/car size, weight and power bloat. See Minicars? I don't See No Stinking Minicars - Column - Auto Reviews - Car and Driver and the executive summary at Light-Duty Automotive Technology, Carbon Dioxide Emissions, and Fuel Economy Trends: 1975 Through 2010 | OTAQ | US EPA.
    Yeah, the 1st gen Insight was the mileage king. Too bad the CR-Z and Insight II were such disappointments.
