Poor MPG From Prius. Worse From Porsche
Discussion in 'Gen 2 Prius Fuel Economy' started by jyl, Dec 16, 2006.
  1. jyl
    jyl New Member
    84
    Portland
    Our 2007 #5 now has 800 miles. It's been chilly since we bought the car (25F lows to 40F highs) and our driving has been all city, cold start, short trips. Longest trip is 7 miles home to kids' school and 7 miles back. The fuel economy has been around 36 mpg. It has improved a bit since the first tankful, maybe 2 mpg.
    So, I'm not thrilled with the fuel mileage, but given the brand new car, cold temps, short-ish trips, and winter gas, I'm not worrying about it yet.
    The reason I posted this is because I just checked the mileage on our other car, my 1989 Porsche 911. This car usually gets around 25 mpg in mixed city/highway in summer. It's been driven in the same conditions as the Prius, a bit worse actually, typical day is cold start, then 4 miles from home to work, then sit 12 hours and return.
    The Porsche's most recent tank delivered just 13 mpg.
    I guess I don't feel so bad about the Prius' mileage.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Good way to put it into perspective isn't it!
    You're not through break-in (both the car and your own break-in with it), you've figured out the cold weather issue. You didn't mention tire pressure, but I'd definately check those and pump them up to at least 40f/38r (I use 42f/40r, some go 2psi higher in both).
    You'll be back, in the Spring, thrilled w/ your mileage.
  3. Tideland Prius
    16,621
    <div class='quotetop'>QUOTE(John L. @ Dec 16 2006, 09:12 AM) [snapback]363122[/snapback]</div>
    Indeed. Most people notice their Prius mileage but tend to forget their previous vehicle (or other vehicles in the garage) undergo the same effect during winter.
  4. Wetnabber
    Wetnabber New Member
    23
    <div class='quotetop'>QUOTE(John L. @ Dec 16 2006, 01:12 PM) [snapback]363122[/snapback]</div>
    I have a question about Prius mileage. I am thinking about taking my 06 Prius to Ziebart and having it undercoated to cut down on road noise. First would this mess up the Toyota warranties, and second, will the weight of the undercoating (I think Zeibart uses a heavy coat) lower my gas mileage?
  5. Tideland Prius
    16,621
    I can't say about the first part (although I don't see how it can affect the warranty) but it will lower your gas mileage since it adds weight.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    The short trips and cold weather are really contributing to the low mileage.
    In addition, since the it's so cold out, I suspect you're using the heater, which unfortunately tends to cause the ICE to stay on or cycle on more. I've observed this many times myself where I'd just started up cold (after 9 hours), drove a very short distance (<1/ 2 mile) w/the heater on and then stopped a a traffic light w/the ICE running. It continues to run and then stops the instant I press OFF in the climate control screen.
    Luckily, I don't have to go much further before I get on the freeway, so as I enter the freeway, I turn the heater/fan back on since I know the ICE will HAVE to run since I'll be going well above 42 mph.
    FWIW, when Consumer Reports tested the Prius in their driving cycle, they got 35 city/50 highway, 44 overall. See http://www.consumerreports.org/cro/cars/bu...s-206/index.htm.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(Wetnabber @ Dec 16 2006, 07:01 PM) [snapback]363237[/snapback]</div>
    I believe the concensus for all cars is that undercoating is not necessary and could be detrimental if it blocks a drain hole.
    On asphalt I don't notice any road noise but in OH and IN on concrete she wailed like a banshee. I don't know if it was the tires or lack of soundproofing.
  8. Joe Bernard
    Joe Bernard New Member
    If you're doing those 7 mile trips on a cold engine, it will stay on longer to heat it up. I let my car warm up in the driveway until the gas engine shuts down, then I hit the road. Hopefully that helps. You really should be getting a little better mileage. 40 mpg at least in town. Of course, a broken in car and warmer weather will definitely help.
  9. jyl
    jyl New Member
    84
    Portland
    Using the heater (climate control set on 70F and auto) and also the electric seat heaters. I suspect the engine isn't warmed up for 1/2 the drive.
    I'm not worried about the mileage. Realizing that the mileage of the 911 is barely 1/2 its "normal" mpg has made me understand how cold weather and short trips affect mpg.
    Anyway, the Prius is replacing a 1995 Range Rover which gets 15 mpg in the best of times. I suspect the Rangie was getting well under 10 mpg in these conditions. My wife was filling the Rangie's tank every 5 days, at $60 a pop. We estimate the Prius is saving us nearly $300/month in gas.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    <div class='quotetop'>QUOTE(Slow & Green @ Dec 18 2006, 12:44 AM) [snapback]363599[/snapback]</div>
    It doesn't. The best way to warm up a Prius, other than a block heater, is to drive it. The engine is going to run either way, so you might as well use the power directly to move down the road.
    Tom
  11. jyl
    jyl New Member
    84
    Portland
    Just reviving this threat to note that, with summer weather and 8000 miles on the Prius, we're now getting around 45 MPG. Still all city, cold start, short trips.
  12. MarkMN
    MarkMN New Member
    226
    Downtown Minneapolis
    <div class='quotetop'>QUOTE(John L. @ Jul 18 2007, 04:50 PM) [snapback]481233[/snapback]</div>
    That is typical. In my short trips I get about 47 nowadays, but last winter when you got 36 mpg, I was getting 42 in colder weather (no block heater or anything). On 55mph rural highways though, I get about 56 mpg without hypermiling and driving speed limit.
  13. JimN
    7,028
    1,117
    South Jersey
    John & Mark, have you considered blocking the upper grill & increasing the tp?
  14. jyl
    jyl New Member
    84
    Portland
    <div class='quotetop'>QUOTE(JimN @ Jul 18 2007, 05:05 PM) [snapback]481302[/snapback]</div>
    Car is mostly driven by wife and it is getting hot here - 100F some days - so don't want to block grille, she'd probably overheat it. The AC is running much of the time. Am already running 42 psi all around.
