Poor visibility through outside rear view mirrors on dirty/snowy roads
Discussion in 'Gen 3 Prius Technical Discussion' started by Maciej_S, Jan 3, 2010.
  1. Maciej_S
    Maciej_S New Member
    Europe
    Recently I made my first long trip with 2010 Prius. It is winter and so the roads were often snowy and/or dirty. I experienced pretty bad visibility through outside rear view mirrors. The problem was that the dirt seemed to be accumulating particularly intensely on the side windows right on exact spot where I see the mirrors. It seems that the aerodynamics cause the water sprayed by cars in front and my own windshield liquid to first flow around A pillar onto the side window and then to dry out and leave any dirt in those particular places. The problem was augmented because it was pretty difficult to remove the dirt effectively with just a paper on a petrol station.
    I was traveling relatively fast (on Autobahn), 145 km/h~90mph.
    Did anyone experience the same problem. Did you try some remedies?
  2. User37
    User37 Can spell PRIUS
    83
    Italy
    Some cars are worse some better, only solution I found so far is to keep a water bottle in the car (during summer when it will not freeze) or use some water from the windscreen washers.
    Without water you will never get it clean. BTDT :)
  3. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Since I have never experienced that in over 9 years with 3 different Prius, despite having to deal with lots of winter sand & salt mess, I'd say it was the driving speed. I don't go anywhere near that fast.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My 97 Camry was worse. With the aerodynamic design with no channels around the windshield, water tends to run around the sides in all locations. My side windows would have mud streaks all over after they sanded the roads.
    I have a bucket of water and a squeegee in the garage at home. I clean the windows as needed.
    I would keep a spray bottle and squeegee in the car with you. Perhaps one of those combo things.
  5. Tideland Prius
    16,125
    Haven't noticed on the old Prius. On the new one, I have water-repellent front windows so the water (and embedded dirt) slide off the front windows when I'm driving.
