Poorly designed jump start terminals?
Discussion in 'Gen 2 Prius Audio and Electronics' started by macevhicz, Jan 20, 2011.
  1. macevhicz
    macevhicz Junior Member
    Los Angeles
    Is it just me, or is the dedicated jump start terminal (on a 2005 Prius) poorly designed?
    In my experience, it's hard to attach jumper cables... The bolt is recessed a bit, and therefore it's hard to fit jumper cables in there in order to attach to the bolt. To get in to the recessed area, I tried a set of cables with a flange that extends beyond the normal clamps, but it had notches for a normal size post, so it wouldn't attach to that little bolt...
    Seems kinda silly to have a dedicated jump-start port that doesn't accept average jumper cables... Does Toyota sell some special Prius jumper cables or something?
    Anyone else also have trouble fitting jumper cables onto that jump-start port?
    52,396
  3. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    You aren't supposed to attach to the stud, if you look closely above it, you will notice a tab, clamp to this instead:
    3 people like this.
  4. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I think I saw someone suggest keeping an appropriately sized alligator clip in the car that essentially extends the tab to give you something better to clamp the jumper cable onto.
  5. macevhicz
    Los Angeles
    Hmm, well, that would do it! I just never noticed that tab... Something about flipping over that cover made me feel the thing to connect to is the bolt. That tab makes more sense.
    Thank you!
  6. pEEf
    720
    579
    Berkeley, CA
    Yeah, it's easy to not notice the tab at first. I didn't notice it until I took the nut off to add the wire shown in the picture!
  7. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I am missing the red cover, Wasn't there when I purchased the car. I hope Toyota stocks them? Hal
  8. pEEf
    720
    579
    Berkeley, CA
    You don't need the cover, it's probably just there because of the liability lawyers. As long as you have the main cover on it, everything is safe.
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Yes, it's the upright square tab that's the positive connection point.
    But you might still have trouble getting a standard jumper clamp on that thing. So a little electrical alligator clip would still be useful.
    [IMGLINK]http://ecx.images-amazon.com/images/I/31A7EHMMQXL._SL500_AA300_.gif[/IMGLINK]
  10. pEEf
    720
    579
    Berkeley, CA
    Just be careful if you go this route, as it could slip off and then ground against something.
  11. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I have some motorcycle jumper cables that work great.
