Popping in the dash
Discussion in 'Gen 5 Prius Main Forum' started by Gunslingerheel, Aug 10, 2024 at 1:18 PM.
  1. Gunslingerheel
    Gunslingerheel Junior Member
    31
    Raleigh, NC
    2023 Prius
    I apologize if this is elsewhere, but I cannot find the search function. I have a 2011 Prius with a popping noise in the dash when I move the air from the vents to the defrost or vice versa. I researched this online and found the gear in the photo is loose on its shaft. I pushed it back on and the popping went away. I fear, however, that this is going to ultimately break. I cannot access it to see what is wrong as the structure that houses the blower fan and cabin air filter blocks it from being removed. I cannot see how to get to it or what the root cause of the problem is. Has anyone dealt with this issue before and have any knowledge of how to access it or what is the issue(s) causing this? I thank you in advance for your assistance.
  2. PriusCamper
    PriusCamper Senior Member
    11,157
    4,539
    Pacific Northwest, USA
    Won't get much help in a Gen5 Forum for a Gen3 problem, but I reported it to the moderator who will move this thread over there for you.
    #2 PriusCamper, Aug 10, 2024 at 3:11 PM
    soft_r likes this.
  3. Gunslingerheel
    31
    Raleigh, NC
    2023 Prius
    Thank you. I am not really sure what I did. I thought I went to the Gen 3 group. Even I know better.
