Popping sound, only in rain
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jcstites, Jan 13, 2020.
  1. jcstites
    jcstites Junior Member
    lexington, ky
    My 2011 is making an odd popping noise from the front passenger side, that only happens consistently when it is raining or has rained. It has been to the dealership twice and they have not been able to recreate the symptoms.
    It started as a single pop when accelerating from a stop and sometimes when applying the brakes. It has progressed to the sound in the video. It is the lower pitched sound, not the sound of my shoes squeaking on the pedals. Now it also happens when driving at highway speeds and increases with speed.
    It doesn't always happen and is hard to recreate. Most recently, on the highway (70-80mph) it would happen when not accelerating and would go away under acceleration.
    My guess is CV Axle, but wanted to check with y'all before I spend the $ to have it replaces. Thanks for any advice in advance.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Mine made that noise due to bad head gasket and eventually blown engine
    51,141
    how many miles on her?
  4. jcstites
    lexington, ky
    Only issue besides routine maintenance was a rear passenger side wheel bearing, she even has the original brake pads!
    I think it's the axle and can do the repair myself, had to replace them on my Acura TL, but the symptoms were different. I just wanted to check if anyone had a similar issue and what fixed it.
  5. jcstites
    lexington, ky
    Bump. Any ideas? It rained yesterday and the noise was back.
