Featured Porsche Taycan Electric Sports car assembly.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Ronald Doles, Nov 10, 2019.
  1. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    Below is a link to a youtube video of the assembly line for the Porsche Taycan AWD electric sports car. The video is about 28 minutes long. One version is around 670 hp and it's 0-60 time is 2.7 seconds. A little faster than our Prius but then you would have to dig considerably more change out from under the couch cushions to buy one of them.
    I can detail some of what you see but I have been retired for 15 years so some of the process may have changed.
    They don't show the stamping department that forms all the required panels with presses.
    They begin in the weld department where automation is used to spot weld panels to the body. These are called white bodies at this point as they are unpainted. The parts and bodies can't sit more than a couple days before rusting begins. Next is inspection and the bodies are wiped down with tack rags before they are painted.
    The first step is primer. The bodies are primered using an e-coat (electrically coated) dip tank. This is a water base paint. They use about 400 volts at 400 D.C. amps with one electrode connected to the car body and the second electrode connected to the tank. The paint migrates to any uncoated surface and is electrically bonded to the body. The current drops off as the surfaces are coated. E-coat is why cars don't rust as quickly as they used to and not everyone uses it. The bodies would go to an oven once it has left the dip tank.
    Next stop in the paint shop. The paint booths have to be maintained at 75 degrees and 75% relative humidity so it is balmy in them. First is the color coat. Most of the paint shop robot guns are electrostatic where a 80kv static charge is built up between the gun and the car body so there is little paint overspray. The color coat is also water based. Once it has been color coated it has to go to an oven to dry that paint. It is usually an infared oven that they attempt to get the body to reach 200 degrees. Any higher and the waterborne paint would boil. Then the body is off to a clear coat booth.
    Clear coat is or used to be solvent based because they couldn't get enough gloss from water based paints. Once the clear coat is applied, the body goes into another oven to dry. This oven is a tunnel, think car wash, heated to about 350 degrees. It is about 1/4 mile long. It us usually U shaped so that both the entrance and exit face the same way so that a draft will not push air through the tunnel. The fumes are drawn off the solvent based clear coat paint as if flashes off into an incinerator that actually provides most of the heat for that oven once the line is started. The bodies move slowly through and the paint is cured. Paint is the #1 complaint of new cars.
    The bodies then go to inspection. The video then switches to the electric motor assembly and finally to body assembly.
    Once the car is completed, it goes onto the dyno and then final inspection. Quite a factory and not very many workers.
    #1 Ronald Doles, Nov 10, 2019
    Tideland Prius likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,071
    4,507
    Pacific Northwest, USA
    I guess this is how you reward rich people for all that money they make destroying the planet. Because once they add one of these eco-conscious race cars to their collection they can finally live a guilt free life.
    #2 PriusCamper, Nov 10, 2019
  3. hill
    8,163
    Thank you very much for the pearls of wisdom - where the the 1 out of a 100 million that have pricy cars in multiples - are destroying the world.
    Stupid me - here I thought the uber wealthy were creating tens of thousands of jobs. I wish our fossil fuel economy had never happened, & we were all still living in caves & enduring tribal warfare with clubs & stones. Then we could all truly be happy. Maybe we should all cell or gas burning cars and start walking.
  4. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I spent years installing equipment in automobile plants and I posted this video because it is typical of how any car whether a Yaris or a Taycan goes from sheet steel to an automobile. I thought that there may be an interest in seeing how that is accomplished. I can't afford a Taycan but I can appreciate the engineering in that plant.
    I guess that a blue collar guy who drives a 3/4 ton 4WD truck with a big V8 as a daily driver could be considered in the same category of destroying the planet and there are so many more of them why pick on the rich guy with an electric sports car.
    Life is so short it would be nice if we got through it with as few regrets as possible.
  5. PriusCamper
    11,071
    4,507
    Hell hath no fury for anyone who refuses to worship at the feet of billionaires and defend their purity, right? And you may criticize me all you want for pearls of wisdom, but what's even more sad is you counter with lumps of coal that attest to your total cluelessness of who's most responsible for carbon emissions, 71% can be attributed to just 100 corporations that are controlled by a small number of billionaires: Just 100 companies responsible for 71% of global emissions, study says | Guardian Sustainable Business | The Guardian
    But go ahead, offer more lumps of dumb coal as rebuttal yet again. Maybe you'd like to argue on behalf on the sanctity of corporate immunity and how none of them are ever to blame for anything, not even mass murder, because clearly its the fault of their customers not them right?
  6. bisco
    49,402
    curious sidebar: in the 2 year old guardian article, volvo claims all their cars will be ev or hybrid in 2019. haven't read anything recently.
  7. PriusCamper
    11,071
    4,507
    I did see Volvo recently announce a new all EV vehicle assembly plant... But as Tesla will attest... Things often don't go as fast as planned...
  8. hill
    8,163
    sorry- didn't mean to hurt your feelings but you're off by about 70%. Try just 1%. It's really not the evil corporate Boogeyman.
    https://skepticalscience.com/volcanoes-and-global-warming.htm
    Iceland volcano gives warming world chance to debunk climate sceptic myths | Leo Hickman | Environment | The Guardian
    So ... beware when too many people cry, "there's a crisis!". Yea - don't sell your Prius & start walking just yet .... unless you want to.
    #8 hill, Nov 10, 2019
  9. Trollbait
    11,518
    Except for the V90 and 40's, all the the Volvo models available in the US have a PHEV option. They are power hybrids with EV range shorter than the Prime, so they don't see much discussion time here.
    The article on the Volvo announcement linked in that one said BEV, PHEV, or mild hybrid. So their 100% EV and hybrid could count 48v systems. At some point, cars will have to be at least mild hybrid for China. Then Europe has regulations and incentives around cars' carbon emissions. I expect the hybrid and EV only line up to filter to the US last.
  10. hill
    8,163
    since Volvo is now a wholly-owned subsidiary of the Chinese company geely, that would make sense.
  11. PriusCamper
    11,071
    4,507
    Congratulations... I will make sure to never see any clueless denialist anti-sciene post you ever make on here again... Oh and what about Methane emissions? Oh yea that's right, whatever the fossil fool industry tells you to parrot on their behalf you'll do, in this case no need to consider methane right? I mean why would methane have anything to do with greenhouse gas, right?
  12. bisco
    49,402
    The robotics are amazing, did you install this type of equipment?
  13. hill
    8,163
    quick note there are several videos of production, but none seem to include the battery cell, into modules, into the main traction pack, as well as it's cooling system. Hope to here they have high hopes for large production numbers, but Porsche usually doesn't set that as a goal. VW? Yeah that should be good numbers.
  14. bisco
    49,402
    Anyone beyond Tesla will be a pleasant surprise
  15. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    nice video
    I was amazed too to see the lack of workers.
    But seems they put a lot of them in inspection processes.
  16. vvillovv
    vvillovv Senior Member
    3,616
    1,273
    NY
    The first time I priced a 911, it was $10k in the late 60's, and the last time I priced a Carrera about 15 years ago it was up around $200K.
    I could go look what they are getting for the Taycan, but I'll wait till I actually see on at the Glen when the Porsche club has one of there track days.
    Thanks for the great write-up and the video. I wasn't aware waterborne paint has been available for as many years as you mentioned above. I'm still having a hard time finding any available retail. I'll also have to do some more research on which solvent base clear Toyota uses or if the clear they now use is also waterborne.
    One question that occured to me while watching the video was about repairs and if the assembly line workers know the disassembly methods for those impossible to get at components every car seems to have at least a few of.
  17. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    Yes. I spent 8 months at Honda when they built a new plant. We designed, built, programmed and installed $42 million dollars worth of automation in the paint shop. At the peak of the job, we had mechanics installing equipment everywhere and 165 electricians running pipe, pulling wire and making terminations. It was like an anthill. During construction, it is a dirtier and more dangerous place because of the welding, burning, grinding etc.
    As the job approaches completion, there are cleaners everywhere, staircases replace our ladders, handrails pop up everywhere and then everything you touch seems like it has just been painted five minutes earlier.
    Of course the automation 15 years ago wasn't as sophisticated as what you see in the Porsche plant because of changing regulations and technological advances.
    We built the paint shop and another company built the weld shop. The paint shop robots aren't as sophisticated as those in the weld shop as you could see from that video. In the paint shop, robots are non contact. They follow profiles above the body whereas the weld robots have to place each component precisely and then weld it in place. Spot welding all those pieces to make a car body is something else.
    Every 3 years or so, there is a new model changeover. For a couple months before the introduction of the new model, we would arrive on Friday night, install any mechanical changes required for the new body style and backup the current PLC program and download the revised programs and test to make sure the new hardware/software works. Then on Sunday evening, we would change back to the original hardware and dump the original program back in so they could continue with the current model build on Monday morning. On the weekend prior to the new model, we changed everything over so that on "day one", the new model build begins without a hitch. We are still on site for a few weeks after new model to make small adjustments.
    After spending months putting one of these lines together, watching them operate is "like poetry in motion".
    Trollbait and dig4dirt like this.
  18. bisco
    49,402
    amazing when you think about it. all that investment saves so much down the road, and higher quality too
    the whole design process of the robotics must also be amazing to see.
  19. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    As far as the paint department, there were two main paint lines referred to as Topcoat 1 and Topcoat 2. Once the cars came out of the ovens for those lines there were inspections. If any paint flaws were discovered there were several repair booths and ovens where they could be sanded and then repainted before being sent forward to assembly.
    I saw 50 completed Accords behind the stamping department one day. I asked the engineer that was escorting me why they were there. The process is when they find a problem with a car, they quarantine 25 cars ahead of and 25 cars behind the problem vehicle and they keep a close watch for that problem for the rest of the run. He walked up to one at the beginning of the line and there was documentation with it.
    The documentation stated that there was a twist in the right door pillar. A twist is when you form (stamp) a piece of metal and it is stretched or bent to the point that the surface becomes rough possibly on the verge of tearing. Their dies and the sheet metal their supplier provided were tested together and worked fine so this was probably a flaw in a section of a single coil of steel. The problem should have been caught in stamping department inspection but it somehow was missed. There would be feedback to stamping about this flaw so they can improve their inspection procedures.
    After the car was completed, the final inspection caught this because it is more visible once the car has been painted and the metal is glossy.
    Mike pointed out the rough texture of the metal in the top corner near the windshield to me. I could barely see the flaw and asked "you're going to quarantine 50 cars for that". He said the company that sold us that coil of steel will be buying those cars. He said every vendor that sells us components is responsible for their quality.
    The four departments stamping, weld, paint, assembly rely on the previous department to provide a quality component. Each of those four departments had signs over their doors "Who is my customer". Weld is stampings customer etc.
    #19 Ronald Doles, Nov 13, 2019
  20. hill
    8,163
    Automotive water based paints have come a long way from the days when lacquer without clear coat would give you a gloss that was slicker - mirror shinyest - bar none. So much so, that if there were the littlest bit of orange peel, you could see it from several feet away.
    Ok - yea it definitely WAS an environmental nightmare (as was its M.E.K. laden primer) ... but it could render a picture perfect result - but make sure your respirator is good & tight.
