Portable battery to charge Prime available?
Discussion in 'Prime Main Forum (2017-2022)' started by Mal McMallow, Jan 20, 2022.
  1. Mal McMallow
    Mal McMallow New Member
    25
    Pittsburgh, PA
    I'm wondering is there a consumer battery that can be used to charge a Prime? I have no parking spot at my rental so can't charge on the street. I occasionally charge it at charge points but would like if I could use more of the electric side of the Prime. Ideally in my situation there would be a battery that I could charge at my place and then take it outside and charge the car when it needs it. Is there anything like this on the market?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    If there was it would weigh several hundred pounds and be the size of a large suitcase.
    Tahsin Shamma likes this.
  3. ChapmanF
    15,433
    ... but it could have motorized wheels to help you get it outside.
  4. dbstoo
    dbstoo Senior Member
    1,321
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    There have been several companies that have developed "portable charging stations" for EV use. One company was promoting it as a quick charge for a tow truck to carry instead of jerrycans of gasoline.
    The down side of using a battery pack to charge your prime is that there are conversion losses each time that you charge or discharge a battery. Arranging for a long extension cord is much more practical and better for the environment.
    triggerhappy007 likes this.
  5. bisco
    49,371
    generator?
  6. bisco
    49,371
    what we need is a robotic charger that you can call on an app
  7. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Given the cost and hassle involved, maybe just using charge mode doesn't seem so bad?
  8. bisco
    49,371
    have you tried one of those jump packs?
  9. Mal McMallow
    25
    Pittsburgh, PA
    I would go the extension cord route but there's only street parking in my neighborhood. Unfortunately there's only parking on the opposite side of the street so I'd have to run the cable across the street. I'm sure this would not be a good look and would probably end badly.
  10. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
  11. John roden
    John roden Member
    67
    29
    West Falls, New York
    You can charge it with your gas engine sometimes or just not worry about it. A normal hybrid Prius might serve your situation better, but just charge when you get a chance and don't sweat it.
    PT Guy likes this.
  12. Mal McMallow
    25
    Pittsburgh, PA
    that's a big boy
  13. ChapmanF
    15,433
    I have a jump pack that holds 29.6 watt hours.
    If we were able to use that to charge the Prime's traction battery, then at the Prime's published 259 watt hours per mile, it would move the car nearly 604 feet.
    Which, thinking about it, is really kind of impressive. :)
    #13 ChapmanF, Jan 21, 2022
  14. dbstoo
    1,321
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That's simply a 9kw gasoline powered generator. It would work, but most generators create more pollution per killowatt than a car does. That kind of cancels out the who reason for going to electric cars.
  15. Salamander_King
    10,970
    8,853
    New England
    I agree. I believe it is marketed as a commercial product for a roadside assistant for stranded BEVs or as a supplement to blink networked chargers where the electric grid is not available. I would not think there is a good use case for residential applications. That being said, the spec of this gas generator must be really good. It states "The mobile plug-in charging unit can deliver up to 1 mile of charge per minute." Obviously not for PP though.
  16. dbstoo
    1,321
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    With a level 2 charger we get around 1 mile per 5.2 minutes of charge on a Prius Prime. (If my math is right)
  17. vvillovv
    vvillovv Senior Member
    3,606
    1,270
    NY
    I got the same 5 min 12 sec per EV mile using the EPA rated 25 EV miles and 2 hours 10 minutes charging time empty to full. Newer Primes have been reporting a flat 2 hour L2 charge time in some cases with would bring the time to 4 min 48 sec / EV mile. It's all over the place for owners who get both less and more than EPA rated 25 EV miles. I've seen one new Chargepoint install finish up a full charge on my 2017 in a bit less than 2 hours, like an hour and 50 minutes. The standard works well in this case as long as everyone is on the same page. ;)
    dbstoo likes this.
  18. Salamander_King
    10,970
    8,853
    New England
    Considering the fact CHG mode can fill the traction battery at 1%/min at stationary idling (1mile/4min) or 2%/min while driving (1mile/2min), using CHG mode on PP is probably the fastest way to charge. And likely more efficient and cleaner than using a gas generator.
    dig4dirt and dbstoo like this.
  19. Mal McMallow
    25
    Pittsburgh, PA
    Please make me understand CHG mode. If I'm using gas to charge the battery why wouldn't I just use the gas engine to drive rather than charge the vehicle?
    jerrymildred likes this.
  20. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I think you understand it perfectly.
    I think that CHG mode is only useful in a VERY limited number of situations.
    I have often wondered why it is even there.
    Wonder what the owners manual says about it ?
