Portable satellite units -No antenna needed?
Discussion in 'Gen 2 Prius Main Forum' started by Jennjay, Nov 6, 2006.
  1. Jennjay
    Jennjay Member
    142
    Fort Myers, FL
    Has anyone tried the portable satellite receivers that have a built in antenna. I would love to have a unit that I can bring in the car, plug into the aux ( or use with FM transmitter in my wife's 05) and go without the need to put an external antenna on the dash or roof . I'm dubious of these working well though. I would prefer Sirius to XM, but either would be fine. If anyone has any experience or insight, it would be appreciated. Thanks
  2. NCPriusGrl
    NCPriusGrl New Member
    16
    North Carolina
    I haven't tried it, but if you are worried about putting an antennae on your roof due to paint scratching or something, you can do what I did. We cut a piece of chamois out and put it between the antennae and the roof. The magnet is strong enough to hold and the chamois prevents the paint from getting scratched.
    I have XM and have a permenant mount for my receiver and can remove it when I need, and so I have never tried the portable units. My mom uses a portable (in her Chevy SSR) and just throws the little tiny anntenae on her dashboard when she drives.
  3. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    <div class='quotetop'>QUOTE(Jennjay @ Nov 6 2006, 06:42 AM) [snapback]344418[/snapback]</div>
    We use our little Sirius receiver both at home or in the Prius. Tried a sat receiver with a built-in antenna and it didn't work well at all. The Sirius model Starmate comes with an external antenna (strong magnet base and quite small) and fits beautifully alongside the vehicle's existing stub radio antenna just above the hatch door. That also looks after using the Sirius transmitter function to provide the signal to our Prius' FM radio on 90.1 ( in our case). Running the cable through the vehicle to the little sat receiver which we keep in the lower drawer under the center armrest was easy. [attachmentid=5615][attachmentid=5616]
    Gary
  4. aaf709
    3,862
    2022 Prius Prime
    I have a portable XM radio, which has both a built-in antenna and a plug for an external antenna. The external antenna is mounted much like Canuck did behind the regular antenna. When I'm in my wife's car, we use the built in, but I have to align it just right, or I lose the signal. Generally I have to hold the radio, so I can move it as needed.
  5. prosec34
    prosec34 New Member
    The internal antenna on my portable Pioneer Airware is practically worthless. You'll absolutely need an external antenna.
  6. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    We use the XM Radio MyFi from Delphi. It has an internal antenna but because all of these satellite based services need to see the southern sky at all times the unit works flawlessly if you get the mobile kit. It also comes with a cradle which serves to power it from the car as well. The wife liked it so much she....ahem....stole it from me and now has it all the time in her car. hehe. I can't complain, however, because I have the factory XM in my Prius I ain't complaining. The car kit, by the way, comes with a tiny (almost postage stamp size) magnetic mount antenna. Just run the antenna cable to the cradle and your done. It has great reliable reception.
  7. edvalencia
    edvalencia Junior Member
    Lancaster, CA
    I was running the Starmate in my '01 Prius using the FM modulator and external antenna. It sat in a cradle that mounts to the front windshield. I found that the sound quality using the FM modulator is not the greatest. I tried several different stations, but kept getting interference. Since I never listen to regular FM radio, I removed the FM antenna and it worked great ever since. From the looks of the 2nd Gen's antenna, it may not be as easy to remove.
    *EDIT: Wow, Just noticed I revived a really old thread...
