Portland to Sacramento on one tank???
Discussion in 'Gen 3 Prius Fuel Economy' started by Soldmytruck, Apr 9, 2012.
  1. Soldmytruck
    Soldmytruck Junior Member
    Portland, OR
    Has anyone ever attempted this and made it? Or in the opposite direction? (Gen III - 2) (stock 15's)
    I don't know the exact address in Sacramento, but from my house to the Sacramento city limits it's 580 miles. If I fill up with Premium and top it off, max out the air pressure in the tires, do you think it's possible?
    We'll be traveling starting at 8pm, so traffic should be ideal for using the cruise control (65-70mph).
    i just made a 140 mile RT from Portland this weekend down I-5 in not ideal traffic and also driving between 70-80 mph with regular unleaded and still averaged about 50mpg (calculated). My primary concern is what happens to my MPG once I hit the Siskiyou Pass. I know I'll make some of it up coming back down the other side, but going up and over.............who knows.
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    SoldMyTruck - Since you are transporting a high-value, Estrogen-Fueled Passenger, most whom love and require HVAC-controlled cabin temperatures, I think you should plan on making one Pit-Stop/Fuel-Stop/Comfort Break.
  3. fuzzy1
    10,355
    Possible? Yes. Certain? No. Not with enough certainty that I would attempt it, especially when handicapped by premium fuel, high speeds, and cruise control. I want a few gallons of safety margin to cover various uncertainties and unexpected conditions, and you would have no margin at all.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    If you were talking regular unleaded, (heck, go for E0 unleaded) a max of 60 MPH with hypermileing, I would give you a better chance, but why attempt this in the first place? Can YOU go from Portland to Sacramento without needing to pee?
  5. Soldmytruck
    Portland, OR
    "If you were talking regular unleaded, (heck, go for E0 unleaded) a max of 60 MPH with hypermileing, I would give you a better chance, but why attempt this in the first place? "
    So, do I not stand to gain any MPG by running Super Unleaded?
    I'm trying it for the same reasons everyone else tries to do silly things with this car, because I can. :) As long as it doesn't rain I think I can make it. I'll also be carrying a spare 1 to 2 gallon gas can with me just in case.
    I'll just let everyone know the results after I make the attempt. This won't be until early June, so check back around 6/2 or 6/3.
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    My Gen 2 manual warns against higher Octanes, I do not see that warning in your 2011 manual, but it will not improve MPG as Premium has marginally less energy than Regular. It may improve power on a sustained uphill.
    Octane rating - Wikipedia, the free encyclopedia
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just for kicks, try Jimbo's challenge.
    I'd actually be more impressed with that accomplishment.
    And if you can't? You might find an additional use for one of those spare gas cans.
    You could become the Charles Lindbergh of Hypermiling and Bladder Control.
  8. Soldmytruck
    Portland, OR
    I might be able to do it (not that I would), but the wife has a bladder the size of a walnut. If I can get there with just two bathroom stops it will be a miracle.
  9. Soldmytruck
    Portland, OR
    Okay, so I just read the Wikipedia link on Octane and another one about tire inflation. You techy guys are just taking all the fun out of this P-Town to Sac on one tank attempt.
    Regarding the issue of Octane. This just goes to show you what decades of anecdotal information regarding Ocatane and increased mpg gets you............ a big red frowny face.:mad:
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you keep your speed at 60mph and lower, don't hit bad weather, reduce the number of pit stops AND run past the flashing PIP then I bet you could do it. You may want to top off just in case. Gas stations get sorta sparse around the Williams/Arbuckle area.
    I just made a trip from Woodland to Monterey and back with 477miles when the gas light started flashing. Mpg was at 50 and my cruising speed was 70-75mph. I made lots of in-town trips down there which hurts mpg. If I ran it passed the flashing PIP for another 100 miles I would have matched your trip idea. Slow down to 60mph and you'll have this one in the bag without having to risk the flashing PIP for long.
  11. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Not shutting the car off and leaving it in Ready mode during those stops will save fuel by avoiding the mileage killing warm up cycle, but only up to a certain length of stop. Does anyone know what the break even time is where shutting off the car is more economical than leaving it in Ready mode? I've never seen a posting on that calculation.
  12. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I drove from Camas, WA to Corning, CA which is north of Sacramento. I'm not sure how much farther you would have to go but I also started NE of Portland too. I traveled 524 miles on 9.82 gallons for a 53.4 mpg ave. I was not trying to get better mpg, I just drove it at 65-75 mph. I also had the CC set going up the pass which used more fuel but I was impressed how it held the speed no matter what the grade. It would be easy to do if you kept your speed at 60 & below & didn't try to hold a higher speed up the passes. If it's raining though it will be a bust. You will need dry roads & no killer headwind either.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    At 65-70 mph, wind will be the deciding factor.
    By the way, you will want to avoid draining the fuel tank completely, even if you have spare fuel in the car. 1 - 2 gallons is not enough to reset the fuel gauge.
  14. fotomoto
    fotomoto Senior Member
    5,634
    3,808
    So. Texas
    So that means you'll be arriving sometime in the middle of the night with a good chance of running out of gas when many (most?) stations are closed or being patronage by "interesting characters". Factor in you'll have a couple of chances along the way to quickly and conveniently top off while stopping for bio-breaks and/or food. Finally, you'll be with a female who might be exposed to danger in a worst case scenario if left stranded.
    Instead what you want to think about is being efficient. Combine your bio/food/fuel stops into one. MUCHO time saved.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Corning is almost 100 miles from my house (Woodland) and it's another 15-25miles into Sacramento depending on where in Sac you need to go. I agree that rain or heavy wind will kill this attempt.
  16. fuzzy1
    10,355
    Is this even an issue on the GenIII?
  17. direstraits71
    367
    65
    Maybe not as much as in Gen2, but I think there's still a warmup cycle that uses more fuel which always occurs after a start up versus leaving the car in Ready during a short stop. Gen3 certainly has a quicker warm up than Gen2, but doesn't Gen3 also have a warmup ICE cycle on restart even with a warm engine?
  18. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    My thoughts exactly.
    Could you? Maybe. Should you? No. :)
  19. walter Lee
    1,126
    376
    Maryland
    Premium gas 89 oct gas will not help but 100% gasoline (no ethanol) will. There are iphone/android apps and websites that can help you to find gas stations that sell 100% gas. Marinas often sell 100% gas. Non urban areas sell 100% gas too. Urban areas almost always sell 10% ethanol gas which has about 7% less energy than 100% gas.
    At sustained high speeds at +70mph, use the recommended tire pressure setting 35 psi front, 33 psi rear. If you are going to hypermile and keeping your speeds between 50 mph to 65mph then setting the tire pressure a tad higher than the recommended 35/33ps at 38psi/36psi might give a slight edge boost in MPGs. Save upping the tire pressure to 44/42psi for when you dont have to go faster than 40 mph.
    You can get a tad more gas into the 2011 Prius than the spec of 11.9 gallons. At the first fillup auto click off, shake the car, wait 30 second, then fill up slowly until the 2nd click - this will often get you +12 gallons in the tank -- because you've just fill up the fuel tank vapor pressure release valve too). This will extend your range a bit.
    You still should get 50mpg if you drive nonstop so your range is about 575 miles. You might be able to extend that range over 600 miles if for part of the way you hypermile using a technique called Driving With Load (DWL)where you accelerated on the downhills and decelerate on the uphill grades. You can extend your range by giving yourself more time to get to your destination and lowering your cc top speed under 65mph. Using cc - a Prius MPG/range incrementally increases as the cc speed drops from 65mph to 50mph
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    My arithmetic say E10 has 96.5% the energy of 100% petrol on a volume basis.
