Possible 12-volt issue?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Psych_Prof, Dec 6, 2010.
  1. Psych_Prof
    Psych_Prof New Member
    53
    Southwestern Illinois
    So, I went to get in my car this morning, and it gave the usual greeting signal as soon as I touched the door handle. However, when I got in the car and pushed the power button, the button illuminated to green as it does in "Ready" mode (I checked and it really was green, not amber), but the dash stayed black. And, I mean it was *completely* black. I pushed the button again, and everything illuminated as normal. I drove to work and back (several hours later) with no issues.
    Other relevant info: This morning is about the coldest we've had so far (below 20 deg. F).
    I combed the forums but couldn't find anything exactly like this. Do you guys think it is a battery issue? Is this worth a trip to the dealer to avoid the risk of getting stranded somewhere?
  2. jdenenberg
    jdenenberg EE Professor
    3,831
    1,824
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A similar problem occurs in some 2004-2009 Prii. See the post by PEEF in this thread:
    http://priuschat.com/forums/gen-ii-...d-weather-issue-speedometer-display-dead.html
    JeffD
  3. Bob Comer
    Bob Comer Active Member
    708
    454
    South Carolina low country
    I have a 2010 Prius and the green light on the power button lights as soon as I press the brake pedal (dash stays black) before I press the power button, so maybe you didn't press it hard enough the first time?
    Or maybe my green light isn't supposed to come on as soon as I press the brake pedal.
  4. peterjmc
    917
    188
    Clarksburg, MD
    Same thing happend to me this morning.
  5. GoSkins
    GoSkins Member
    132
    Frederick, Maryland
    It happened to me some months ago. It wasn't cold. It hasn't happened again. I credited to not pushing on the brake.
  6. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    Same here several times and placed the blame in the same place ( me and the brake pedal)
  7. fotomoto
    fotomoto Senior Member
    5,596
    3,770
    So. Texas
    I'm another who's experienced a too quick/sloppy with the brake pedal. I wonder if the cold makes the brake switch stick?
    If it's the 12v, you probably should have other issues. The 12v in my wife's Cube just went out at 16 months so it's certainly a possibility and shouldn't be automatically ruled out.
