Possible bad AUX battery or parasitic drain!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Andrew863, Aug 9, 2021.
  1. Andrew863
    Andrew863 New Member
    KY
    So a couple days my wife had a issue getting the key to read and go to ready mode so I changed the key battery. Then I did some research and some people said to look as the aux battery. So I checked it right after she drove the car and it was 12.7 volts. Then after setting for 24 hrs it was 10.5 volts. So I thought its a bad battery. The guy I bought the car from replaced the battery less then a year ago with a Toyota battery. This has me thinking maybe it is a drain then. I let the battery set for 10 hrs withe the battery un hooked from the car and it stayed up at 12.7. So could this still be the battery or do you think I have a drain and if so do you have any ideas?
  2. JC91006
    16,480
    8,397
    you can get your answer by doing a load test on the battery. Most auto parts places can test it for free
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Well one would THINK that would be true.
    But the sad truth is that many places that test batteries don't do it right.
    It needs to be "hit" by the tester several times on a row and almost nobody does that.
    His "test" does tend to point to a parasitic drain.
    But a tiny one is normal.
    It still could be a failing battery.......but not likely.
    49,437
    it sure sounds like it. but without confirming with a load test, it could be that the battery just can't handle the normal drain.
    do the load test first, and hope it fails. finding a random electrical fault can be tedious to impossible.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,503
    NJ-USA
    I would suggest having the 12V battery properly charged and tested. The two most common testing methods are 1) an electronic tester that uses capacitance to estimate a battery's "potential" capacity and 2) a "carbon pile" tester that applies a resistive load to the battery that is 1/2 of its CCA rating for 15 seconds. I would do both tests.
