Possible bad clock spring
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hybridHero2008, Mar 1, 2020.
  1. hybridHero2008
    hybridHero2008 Junior Member
    I have a 2008 prius touring with 223000 miles and the buttons for the defroster on the steering wheel only work when the wheel is turned to the right. All the other buttons on wheel work fine. Could this be a clock spring and if so can anyone recommend a good aftermarket clock spring that is reliable. Thank you.
  2. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    I'm afraid we can't recommend aftermarket clock spring because they just don't seem to last. Look for an online dealer and buy an OEM one. They are about $125 - $150.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Or, if you're as cheap as I am and have a source, I got one from a friend whose business pulls parts from wrecks. It was about $50, iirc.
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I think there like 100$
  5. hybridHero2008
    Thank you all for advice I am just going to go with original
