Possible battery problems , which one? plus engine lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Apr 17, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    Hi all,
    I've got a topic that I can see has been covered many times, and all of the answers have been pretty educational!
    So my car is Gen II, 12 years, 164,000 miles, has been a very low maintenance car so far. The 12v is 3 years old, optima yellow top. Recent oil change, fluids all full, and I believe I can see movement in the inverter coolant tank. The problem is that 4 lights came on a couple days ago: RTD (red triangle of death) VSC, (!), and also the more common check engine light. The main symptom up until now was that upon starting, the few blue bars that were left would turn to 1 purple after a couple of minutes of driving, then the battery would go all the way back up to full green in 3-4 minutes. After that all is normal. Except for today, I started having acceleration and power problems. A slight hesitation when accelerating from stop, and some power issues (to put it mildly) when going up a large hill on my commute. Almost didn't make it to the top.
    The battery diagram on the screen on my most recent, and thus far longest trip this week (30 min each way) was full green most of the time which is really unusual. The energy flow according to the display screen is also strange. The power is almost only going toward the battery, and never away from it even when going up hills. It's as is the battery is only being charged and not drawn from. The mechanic at Meineke who changed my oil today also found a couple of inches of water in the spare time well which I managed to drain out. He suggests water damage to the HV battery.
    I've checked out the 12v battery using the diagnostic screen, this morning before driving, it was 11.1 V before 'ready' mode.
    Meineke couldn't give me any codes to work with. I'll probably bring it to a garage in the next couple days anyway, but I wanted to check in with y'all to hear some opinions.
    The good news is, got my inspection sticker last week before the lights came on (and after the dashboard display started coming back on regulary, there's that too!)
    49,701
    start with the 12v (put a volt meter on the jump point with car off), then move on to the hybrid battery. codes are important, and he may be correct about corrosion inside the battery, or it may have a bad module
    the fluctuating battery level is usually a good indicator of a hybrid battery issue
  3. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    Sorry for the problems. Sounds like a classic traction battery failure. The 12V is probably getting low because the car is trying so hard to charge the traction battery that it doesn't have enough capacity to take care of the 12V. The 12V won't make the battery bars go up & down like that. You should charge up the 12V and try it, just to cover your backside, but I'll be shocked if that helps.
    Since you have lights on the dash, you also have codes to read. Get it checked by a Prius literate code reader. The ones at most car parts stores don't have the codes for the Prius hybrid systems. If you're not a DIYer, a Toyota dealer or hybrid specialty shop is the place to go. If you're handy, there are about 75 trillion threads here on PC about Techstream (Toyota's software) or other code reading possibilities.
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    UGH. Thanks for weighing in. I'm definitely going to get the codes read soon, as well as test the 12v tonight. If the car is otherwise solid, body-wise, and it's been well-maintained, do you think this 12 year old 164.000 mile would be worth the new traction battery? Or time to just move on? I've kind of always wanted an Outback or Forester...
  5. jerrymildred
    11,518
    14,124
    Tampa, FL
    That's a bit of an emotional question, I suppose. If you like the car and it's in otherwise good shape, it seems to me like it would be worth fixing. If you're hot to trot for something fresh, then it's a question of if you'd recover the expenses of fixing it when you sell it or just get rid of it. The only other potentially expensive failures would be air conditioning or brake pump. Other stuff will happen die to age, but they are pretty easy and inexpensive.
  6. bisco
    49,701
    get the subie
  7. bmparent
    bmparent Member
    159
    65
    barre ma
    Good advice man, thanks for that. I've decided I'm going to bring it to a Prius knowledgeble guy tomorrow, and hopefully he'll give me a solid diagnosis. I hope to fix it because thinking about it, I like the car and it's been otherwise very reliable and it's in fine shape but for some minor quirks. I'll keep you updated!
    jerrymildred likes this.
  8. bmparent
    bmparent Member
    159
    65
    barre ma
    So update on the battery, a mechanic confirmed the Replace Hybrid Battery code, and I had all the classic symptoms according to a coupe youtube vids. I used Hybridbatterdoc that I found on ebay while shopping for a used battery. I talked with a real person each time I called which felt reassuring and there was 402 reviews, all positive. No negative reviews. So I set up an installation for 1,000.00, used battery with one year warranty. The guy was at my house in a couple of days, had the old one out and new one in in under 40 minutes. He was able to tell me about every singe part and symptom I asked about. The cars runs good as new. He noticed that the cooling fan vent wasn't fitted properly to the bottom of the battery so he suspected that the battery wasn't getting cooled properly and that's maybe why it died. But who knows, it could be just because it's 12 years old. So, not as big a deal as I thought, and here's hoping the 'new' battery will last me at least a couple of years, if I don't decided to trad or sell first.
  9. bisco
    49,701
    please keep us posted, all the best!(y)
  10. jerrymildred
    11,518
    14,124
    Tampa, FL
    If it was a fairly new used battery and not a hodgepodge of cells from several batteries, it should last several years.
