Possible mod for snow?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bbald123, Jan 23, 2008.
  1. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
  2. prim2
    prim2 Junior Member
    64
    Toronto
    Wouldn't you have to carry them with you? They look like they would take up a lot of valuable trunk space.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    They would work for really bad traction issues, but in most cases, you aren't going to have the ground clearance to go through the sort of snow where you would need these. I would consider them as replacements for chains, as in the mountains, otherwise they would be more bother than worth. If you drive in snow, get good tires.
    Tom
  4. cnschult
    cnschult Active Member
    772
    96
    Michigan
    10 or 12 years ago bridgestone invented the snow tire with their Blizzaks, the blizzaks are still around but Michelin also came out with X-Ice and Yokohama has their Ice-Guards.
    If you get stick in the winter with any of those snow tires than my friend you need a 4x4 SUV or pickup truck. Save those traction gizmos for the infomercials & get some steel wheels & snow tires for the winter.
  5. bbald123
    386
    271
    Harrisburg, PA
    First, snow tires have been around much much longer than you seem to think they have. I used to drive BFG snow tires on front wheel drive cars when I lived in the mountains. Never got stuck with them. Occasionally I got stuck without them. Without studs, they are no help in ice. With studs, you need to be very cautious in ice.
    Second, chains give much better traction in packed snow and ice than snow tires, better even than studded snow tires.
    Third, the point I failed to make was that these should eliminate the traction control paralysis many have faced on their Prius. These are easy to install when needed. The straps live in the cargo area when not needed and the wheel plates stay on all season. Also, you wouldn't take the MPG hit due to the sticky and thick snow tire tread. The only drawback to them that I can see is the price.
