Possible problems?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mcmikey, Feb 5, 2025.
  1. mcmikey
    mcmikey New Member
    I’ve got a 2014 Prius with 152k miles. I’ve owned the car for about 5 years and have had no issues thus far.
    2 weeks ago, CHECK HYBRID SYSTEM popped up on the screen. Car still drove fine, got it home, parked it for about a week. Tried driving it again, wouldn’t go over 25 mph. Checked the codes and did some research and seemed like the inverter went bad. Replaced it with a used inverter and car drove perfect for about 5 miles, CHECK HYBRID SYSTEM popped up again.. but this time seemed like the 12v battery died. Got a new battery from Walmart, put it in and all the codes went away and car runs perfect again.
    Drove it 205 miles, been running good all week.
    This morning the CHECK HYBRID SYSTEM sign came back while I was letting it warm up. I turned it off and took my other car to work. When I came back in the afternoon and started the car, the sign is gone and the car runs good again.
    It has one code showing up P0A08.
    The new 12v battery is at 12.28 volts when car is off, but jumps up to 14.45 when I start the car. I put the battery on charge and I’ll drive it around again and see if anything changes.
    Inverter pump seems to be working, a little bit of movement in the tank when car is on ready.
    The only thing I’ve noticed that a little different is the inverter pump noise when I turn off the car is sometimes keeps going for a solid few minutes. Sometimes it shuts off after about 10-15 seconds after shutting off the car, the other time it stayed on for a while. Always turns off immediately if I lock the car.
    Can anyone point me in what else to check?
  2. Tombukt2
    Tombukt2 Senior Member
    12,987
    2,328
    Durham NC
    That is kind of weird I wouldn't think the inverter cooling pump or any of the electric pumps would keep running much after shutdown The main one for the ice engine might run for a bit so no hot spots are created You're inverter seems to be charging the 12 volt check hybrid system That's a very wide code lots of things in the hybrid system to check maybe take a look at your HV battery just because it's easy to get to in this model easier anyway.
  3. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    How did you get this code?
    What device or program did you use?
  4. ChapmanF
    18,204
    Can you post the first code(s) from before you replaced the inverter assembly?
    The P0A08 code is an issue with the part of the inverter assembly that's responsible for keeping your 12V battery charged. So if there's a problem with that, you can repeatedly end up thinking the 12V battery died.
    Can you record that noise? I also haven't heard of the inverter pump continuing to run with the car off before, though I do learn new stuff every day.
    Edit: a quick look in the wiring diagram shows the inverter pump getting power through the IGCT relay, so if there's a noise continuing when the car is off, I'm thinking it's likely something else.
  5. bisco
    51,937
    12.28v is low for a new battery. Charge it up and see if it holds overnight
  6. mcmikey
    mcmikey New Member
    Yes, turns out it was the headlights making that noise. I put in aftermarket headlights and I guess never noticed how noisy they were
  7. mcmikey
    mcmikey New Member
    Turns out the noise was from the aftermarket headlights I have installed, I unplugged it and the noise stopped.
    I don’t have all the codes from the original problem. But almost all of them had to do with the inverter.
  8. mcmikey
    mcmikey New Member
    EDIT
    After I posted this, I figured out the noise the car was making was the aftermarket headlights I have installed.
    Also, I couldn’t get the 12v battery to get to a full charge. So I returned it and bought another new from Toyota.
    Installed the new battery and I changed the positive side terminal plus the fuse with it.
    Car drove perfect for about a week, 1100 miles. Randomly right after startup today, the same P0A08 code came on. I am using a Innova 5610 code reader, so nothing fancy.
    With the car off, the battery is showing 12.85 volts. So I can rule out the 12v battery being an issue this time.
    After turning the car off twice and letting it sit for a couple minutes.. the code went away.
    Could it be the used inverter I bought, is not working properly? Or something else?
  9. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The fact that the error disappears and reappears may be due to oxidation in some connector or loose contact.
    See the manual on how to check.
    https://attachments.priuschat.com/attachment-files/2022/06/222907_2010_Toyota_Prius_Repair_Manual_-_P0A08.pdf
  10. mcmikey
    mcmikey New Member
