Possible reasons for 10mpg drop in mileage?
Discussion in 'Gen 3 Prius Main Forum' started by krausternet, Apr 12, 2019.
  1. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    I have a 2013 level 3 purchased new in 2013. I have about 65K mileage on it. I usually note what type of gas mileage I am getting when I do gas fill-ups. I can't really say exactly when I started to notice the drop in mileage. Maybe about a year ago, back in 2018 at about 55K or 60K I noticed the mileagefrom always getting over 48mpg, and as high as 52mgp, go down to sometimes 42mpg.
    - My driving habits - ratio of freeway to city driving - hasn't changed.
    - I know that tire pressure can effect it a lot and in the years up to when I saw the drop I was aware that I could tweak out at least 2 or 3mpg by inflating the tires higher. So if they were supposed to be 33, I'd go to 36 or 37.
    - I've now taken to inflating the tires to the high 30s to get back to about mileage of 47mpg for the last couple fill-ups, but the ride is pretty hard and noisy.
    - I took the car in for the dealer's standard maintenance during the first years but have not had a real tuneup ever.
    - I do oil changes about every 5K with synthetic oil.
    - I bought tires last year - costco Ecopia EP422+ Grand Touring A/S 195/65R15 91H. I didn't notice a mileage drop when I started using them. I think it came months after that, so I am reluctant to think it is the tires.
    Any thoughts? Should I do a full service? In the old days a change of points and plugs, new air cleaner, setting the valve gap and timing, etc, was important maintenance. Can I expect better mileage with a full service tuneup from the dealer?
    51,155
    air and cabin filters?
    there is no such thing as a full service with prius. just follow the factory recommendations in your manual.
    check your oil level and 12 volt battery health.
    clean the hv battery cooling fan and intake grille
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    The only accurate way to track mileage is repeated gas-ups at the same pump over several visits. Using the on-board mpg readout has been not-so accurate for me.
    Johnny Cakes likes this.
  4. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Mendel Leisk and Raytheeagle like this.
  5. krausternet
    krausternet Member
    137
    24
    SF Bay Area
  6. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    I am not going buy what the onboard mpg readout says. I simply read the trip odometer and divide that by the gallons on the pump. I tend to fill-up at the same place with the same pump and top it off about the same way.
    KennyGS likes this.
  7. bisco
    51,155
    sounds like a degrading hv battery maybe
  8. padroo
    padroo Senior Member
    2,763
    2,251
    Have you cleaned your MAF sensor?
  9. hill
    8,640
    Alignment?
  10. Mendel Leisk
    40,584
    Yet...
    Also, try a fuel injector cleaner?
    Raytheeagle likes this.
  11. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Sticking brake caliper?
  12. Mendel Leisk
    40,584
    Ah. Were rear brakes (in particular serviced recently? Feel all four wheels after a drive, see if any feel hot. The should be slightly warm at most, and uniformly so.
  13. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    I have an OBD2 scanner that I've never used. I finally plugged it in this morning and paired it to my phone and downloaded a scanner app. (Car Scanner ELM OBD2 by 0vZ) Is there some way I could trouble shoot this possible drop in mileage using the scanner? From the huge list of data output what would I be looking for? I imagine there a lot things that could be read.
