Possible to force car to fishtail/oversteer?
Discussion in 'Gen 3 Prius Main Forum' started by mmichaell, Apr 11, 2010.
  1. mmichaell
    mmichaell Member
    241
    chicago
    Random question -
    Does the Prius III's traction/stability control prevent the Prius from oversteering? Am wondering what would happen if I was driving fast, say around 45mph, around a tight turn or intersection & all of a sudden hit the brakes hard. I also have my tire pressures at 39/35 (front a bit more than the standard 35/33 ratio), so this would make the car understeer a bit less as well.
  2. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I was driving on an off ramp last week with wet roads and no cars were behind me or ahead of me. I took the turn faster than I should (deliberate of course) as I wanted to see if the stability control would kick in. It kicked in and actually stayed on for a few seconds (it makes a sound that sounds like a low pitched beep...beep...beep). The car held steady around the curve and the stability control did its job. Keep in mind that there is a point where this safety feature will NOT save you if you go over a certain threshold. I certainly do not want to test its limits but it works great for times where I like to take a turn a little faster in the white stuff.
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Oversteer is hard in a fwd car even without TC unless your rear tires are in terrible shape.
  4. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    Well the system will not stop the car from over/under steering. But it will make a best effort at self preservation and try and keep itself on the road by applying opposite braking (maybe steer assist - not sure) and beep like mad to let you know it's upset.
  5. mmichaell
    mmichaell Member
    241
    chicago
    I agree with you, most cars, stock, are a bit difficult to induce oversteer. I did have a FWD car that after adding a thick rear swaybar made the handling nearly neutral, so if I pushed it I could get the rear to kick out. This 10 year old car had no traction control, no ABS of any sort, so I'm curious how the Prius would react, given all the new technology that it has.
  6. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Both my Gen 2 Prius's oversteer. Due to battery weight in back. Once those battries/back end start to rotate, tough to control. Add some ski gear or other heavy luggage and the issue gets worse. Always run 2-4lbs more in fronts to increase understeer. 99% of all cars sold to public understeer. this is because a twitchy oversteering car is a bitxh to control.
  7. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Hokay! I can actually answer this one.
    This last December, right after I bought my 2010 Model III, it snowed about 5 inches. I looked at my learner's-permit daughter, said, "You are coming with Me!" and dragged her and the car out to a large (several acres), snow-covered, slippery parking lot that early Saturday morning for skidding practice.
    After a couple of whacks myself, switched places and had her skid the car all over the place. Had her steer funny, hit brakes, gas it, and then do as many at those at once as possible, then recover the car each time. After she was done, got back in there and tried some more fun myself. (The time to learn how to countersteer is not just before an accident.)
    Results:
    1. VSC kicks on early when the wheels start skidding.
    2. I tried to make the car do a donut. Fat chance.
    3. Making the rear end swing like a pendulum was very, very difficult. I don't think I managed to make it happen.
    4. Basically, at 40 mph, you could make the car go sideways some by keeping on the gas and steering hard to the right or left. But the moment you got off the gas, relaxed the steering, or hit the brakes the car would simply straighten out and fly right.
    5. Hitting the brakes, no matter what you were doing, stopped the car. Fast.
    6. Countersteering would stop a skid. So would practically everything else.
    I think you can do a 4-wheel drift in the snow around a corner with this car, but it wouldn't be as easy doing it as was my old 2002 Civic or even older 1971 Beetle. I haven't had the car on glare ice where it can be really difficult going in a straight line, but I suspect it would do a better job than the old 1982 Datsun which put me into the weeds that way one cold day. (Actually, I did get the car straightened out. It was the guy in the lane to my right that then got the wobblies, hit my right rear, which then put me into the weeds. Or snow bank, whatever.)
    I suppose a pro driver could make this car do some fancy donuts, or maybe a truly ice-covered lake would do the same, but that VSC has some bite.
    KBeck
    3 people like this.
  8. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    Looks like the only way to purposely create oversteer is to sufficiently strengthen the chassis and suspension to overpower the effects of VSC. As many have pointed out most mass production cars intentionally understeer. A sufficiently rigid chassis/suspension would create neutral steering, and an overly rigid chassis/suspension could more easily produce oversteer.
  9. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    Good point! Remember not to get too over exuberent in testing out the Traction Control, neither a driver or Traction can overcome the Laws of Physics!
    David (aka Blind Guy)
  10. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Random comment -
    Not sure why you'd want to know this... :confused:
  11. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    All I get is 4 wheel slide and alot of beeping. It's very hard to get Prius over steer without fat rear sway bar, without hand brake, without adjustable shocks, without being able to press accelerator while braking, without race tire in the front etc. and vsc working against this.
  12. mmichaell
    mmichaell Member
    241
    chicago
    Because I'm curious how great the Prius's technology is, for satisfaction that I purchased a good vehicle, and because I am an engineer and like to know of things work? Is that a sufficient reason for you?
  13. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    To break the back end loose in snowy parking lots, the P-brake
    is useful, but probably wants to be in the state where the ratchet
    doesn't keep the pedal down so you can modulate it. Press a little
    way until the ratchet starts clicking, let up, and then it's
    free to push up and down as long as you don't return to the
    full-up position. Whether one could utilize this for fast dynamics
    on dry or wet pavement is anyone's guess, though; I've only
    utilized it in situations where I had plenty of leeway to experiment.
    _H*
  14. deltron3030
    437
    64
    Lakewood, CA
    if one asks a question about oversteer and possibly fish-tailing intentionally, there are a variety of valid reasons why one might ask and plenty of prius owners who could attempt to inform the OP.
