Possible to get 3-door Smart Key in Prius II?
Discussion in 'Gen 3 Prius Main Forum' started by Mormegil, Apr 20, 2009.
  1. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    I don't have a lot of experience buying new cars. I'd just like to know if it's possible for the dealer to have the 3 door smart key system installed as an option on a Prius II?
    I figure it's a bit more complicated than mud flaps and "undercoating."
  2. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I would think the answer is no, as it probably involves a lot of pricey materials and lots of wiring. But then again, nothing's impossible :)
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I would appreciate a confirmation of the Prius Smart Key - I vs II. So, if I understand correctly:
    - Prius I - no need to remove the fob from your pocket/purse to unlock the driver's door and start the car - Right?
    - And, 3-door for Prius II - unlocks the passenger front door and hatch as well.
    So, it does use a proximity sensor as in some luxury makes?
    I'm very seriously considering the 2010 (have a Lexus RX now). The Levels / Packages for the Prius are a bit confusing, but you folks on the board and the Prius Team sure assist newbies here.
    BTW - I test drove the Insight yesterday.
    Top 3 negatives - interior size - front to rear...too cramped. The dashboard...very convoluted, although the info screen for hybrid op and other data was quite good. Rear visibility...huge blind area in both rear corners, specifically due to the wide mounting piece for rear seat shoulder belt mechanism - the rear window doesn't seem to be as wide as the Prius. It drove and handled quite well, but I wasn't "into" the test drive as I had already wrote it off due to the aforementioned items.
    Also stopped at the Toyota dealer - they have 13 09's on the lot. Put my name on their '10 list. Barcelona Red and bisque (unsure if leather or not). And solar roof - would be invaluable here in Florida.
    Oh! the Honda dealer had leather installed in the Insight - had 3 cars in stock. The leather was a $2K charge and felt like pleather. They also plugged on Honda pinstripes and hokey mag wheels - as well as a $395 "appearance package", and more....typical. Dealer MSRP 25,650. Some sap will probably buy it...
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    1 door SKS would include driver side door sensor (exterior) and center console (interior) sensor.
    3 door SKS adds the passenger door sensor, trunk sensor, and probably rear hatch sensor if not included in 1 door. Sensors have a range of ~2-3 ft.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
  6. BH1973
    BH1973 Junior Member
    What? You mean some 2010 Priuses will only open the driver's door with the smartkey? My 2004 has drivers, passenger, and hatchback buttons. This would really be skimping.
  7. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    I wonder if I could buy the 3 door sensor system from Toyota and install it myself. It would probably require a new keyfob and cost an arm and a leg.
  8. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I agree. It would probably cost less to buy a Prius IV with the options than to try to install the SKS after the fact in a Prius II. It may not even be possible.
    This question was posed to me before so I'd like to inquire to you as a potential buyer...'Why is the 3 door SKS important?' It's not a sarcastic reply I'm trying to understand the need.
    I have a feeling that there may be a 'way around' this lack of functionality.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Although I'm not in the market for a 3rd gen Prius, I've been a little dismayed about the requirement of having to go w/model IV or V to get 3-door smart key.
    There are a couple reasons and I do this now w/my current Prius. In all of these cases, it's nice to be able to do this WITHOUT pushing buttons on the fob AND WITHOUT going to the driver's door first (I have mine set to unlock all doors upon touching the driver's side black strip on the back of the handle):
    - opening the hatch
    - opening the passenger side door to retrieve something (to save wear and tear on the driver's door wiring - I had a power window quit working on my 91 Camry long ago because the driver's side power wire broke.)
    - opening above door for a lady while on a date
    If I had to buy a 3rd gen Prius now, I'd probably get model II or III because I don't like paying for leather and I probably won't get nav (available on model III at minimum) because the premium on factory nav systems is now way too high vs. PNDs. I also don't like paying for heated seats. (I've never owned car w/leather nor heated seats. I also think I wouldn't do a good job of taking care of leather.)
    I'm guessing that Toyota wants to either upsell and/or keep down costs on the lower end models by omitting the extra antennas and wiring.
  10. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    I personally have an '07 that I'll likely drive into the ground, but my wife is looking to replace her 12 year old Chevy. She often has to carry boxes of papers to her car and put them in the trunk. They typically require both her hands. With 3 door SKS, she can just rest the box of papers on the bumper and quickly pop open the hatchback.
    Without she'll have to rest the box on the bumper or put it on the ground, fish around in her purse for her keyes, pull them out either insert the key or press a trunk release button (I don't know how it works on the gen 3), lift, then put the box in the back.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    You know you can still press the button on the fob to unlock the doors if you want to open the left door first. Oops I mean right door.
    You don't need to take the fob out of your pocket or handbag, just press the button as you approach. In some situations it's most likely easier than smart-key but not as clever.
    If you need to carry something get the fob out before you go out to the car and press the middle button as you approach, that's how I do it. As I walk out of my house door to go out I press the garage door opener and the unlock button on the Prius fob, by the time I get to the garage the garage door is up and the car is still unlocked.
  12. BH1973
    patsparks, sure, you can do that, but the 3 door SKS (I actually wish it were 5 door) was a nice convenience that was found on even the 2nd gen package #2. Also, the passenger side and hatchback opened all of the doors. Not having it on the passenger side is one thing, but on the hatchback it's really really useful.
    It's skimping on Toyota's part not to have it standard on all 2010s, pure and simple, and actually a little sneaky. The 3 key SJS so high up on my list of favorite options that it might make the difference for me on whether we buy a (dramatically reduced in price, just wait!) 2009 #2 or a 2010 to replace our 2004.
  13. patsparks
    10,664
    567
    Wait till you see the price.
    Remember Toyota want to put out a competitive product, I want a low price series III Prius, if you want the added options then don't "skimp" yourself, spend the money and get the options package with 3 door SKS.
    My current Prius doesn't have SKS on any doors, having it on one door and inside the car is a step up, not down for me. If you had a base model Prius now it would be the same for you.
    What I would really like is a button on the fob that actually "opens" not just unlocks the hatch, that would be really handy!
  14. BH1973
    When the current #2 Prius has 3 key SKS, it is skimping on Toyota's part not to put it on the #2 package for 2019. In other words, it was basically a standard option on all Priuses save the base package that you have. Now it's become a high end option that's only available with leather seats (which I certainly don't want).
  15. HTMLSpinnr
    5,339
    917
    251
    For those who claim they'd like 5 door SKS, I find a quick pull on the hatch to unlock the car sufficient if I'm approaching from the rear of the car. I've reprogrammed the car (see owner's manual) to do all three doors from any location, so any major direction is handled. I'll do the same on the 2010.
  16. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    As much as I like the 3 door SKS (I'm the OP), I can't really fault Toyota for "skimping."
    I think we're a bit spoiled with the Gen 2 Prius. How many other $22,000 cars out there have a Smart Key system (or an MFD). So it's not surprising they went to a more conventional package system.
    We have to remember the 2010 Prius isn't designed for Gen 2 Prius owners who know better, it's designed for the mass market.
  17. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    As far as I know, all 2007+ Nissan Altimas have the smart key system except for the 2.5 base trim. The lowest trim that has it is the 2.5S which starts <$22K. You can also get them as part of a package on the Nissan Versa 1.8SL. From a quick look, that should run under $18K.
    Neither has a touchscreen MFD though unless you get a nav system on the Altima.
  18. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    Here's my wife's reply paraphrasing:
    Her 1997 Chevy Cavalier ($11,000) has remote trunk release. You'd think a 2010 model costing twice as much would have something similar.
  19. DeadPhish
    2,010
    353
    Yes this is my option as well. I've got my 05 Prius programmed so that a touch of the driver's door unlocks all the doors including the hatch. I too think that they are cutting costs ( in order to keep the price down ) but while I love the SKS feature it doesn't matter to me if it's one door or three door.
    Right now for me it's 5 door. If I was getting a 2010 then I'd program it the same as I have it now. I also think that if enough prople want a full 3 door capability that in later updates that will be included.
  20. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Can the "1 door" SKS on pkg #2 be programmed to unlock all 5 doors ?
    Might be good enough. My wife is sold on SKS.
    Carl
