Possible to replace charger with higher amp version?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jimbo69ny, Aug 12, 2014.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I just had a thought, is it possible to replace the charger that is in our PIP with one that charges at a higher amperage? I am getting a Rav4 EV soon and I like that it can charge at 40 amps. If we could do that with the PIP it would be done in minutes instead of hours.
    51,155
    absolutely, i would love to get charging down to 30 minutes, let us know how it goes!(y)
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    According to Tesla, rapid-charging is not harmful to the battery. Whether their lithium battery is equivalent to either the lithium-based or the nickel-based batteries used in Toyota's hybrids, I'm not sure. Regenerative braking can charge the battery very rapidly as well.
    The significant problem is the charging circuit, which is designed for specific charge rates. Some sort of special equipment would be required.
  4. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    A 6.6kw charger like that in the Leaf would greatly improve the utility of the PiP's small pack. If 10 minutes would give half of the usable range, I'd be tempted to stop and to it off more often to greatly reduce my need for gas.
  5. mrbigh
    3,686
    699
    Long Island, NY
    No possible, the charging rate is determined by the Prius PiP Internal charger and@ 240/208 VAC and 25 Amps is limited to 1.35 hs. You can provide a 40 Amp or 100 Amp circuit (at the above AC voltage) and will be the same charging time.
  6. bisco
    51,155
    agreed, it's going to take some serious technical expertise. we have the people here, but do we have the desire needed to pull it off?
  7. mrbigh
    3,686
    699
    Long Island, NY
    Certainly I will not call it a need but a greed ( with certain exceptions)
    .......and the more important constraint will be, this of modification or improvement will impair 100% the manufacturer's warranty.
  8. bisco
    51,155
    yes, that's always going to be an issue when fiddling with stock technology. you have to want it badly.
  9. Jimbo69ny
    712
    107
    Ithaca, NY
    I agree! Its out of my realm of expertise but Im sure someone could figure it out. If it was too expensive it would be a worthwhile mod
  10. bisco
    51,155
    peer could do it. i wonder if he would be interested in adding this to his bag o' tricks?
  11. CharlesH
    2,796
    1,163
    Roseville, CA
    I would think that replacing the charger in the car would be serious engineering work, and would likely require some sort of control software update. I'm not saying that there aren't some engineers around here who could pull it off, but it's not clear to me how anyone outside of Toyota engineering could do that, with all the interdependencies. Even something that one would think of as mundane, such as the air conditioner, involves working with a dedicated inverter and control circuitry.
  12. GregP507
    3,002
    481
    I'm sure it can be done, but the risks of doing so are far beyond my comfort zone.
  13. bisco
    51,155
    sounds like a car fire waiting to happen.
  14. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    You would probably need to replace the existing on-board charging equipment bodily. It is only designed to work at 13 amps, trying to run more amps through it would tend to melt the existing wires and destroy the existing relays - they're all closely designed around that 13 amp load.
    After replacing the on board charger you would have the issue of how hot the cells would get when you run through that much power in that short a time. We don't know if they are internally capable of charging faster. You might need to upgrade the cooling, or it might not be possible to keep the battery cool without major rebuilding.
    Once you had it working mechanically, electrically, and thermally, you would need to accept that this work would utterly destroy any warranty on the battery.
    All in all I would say it might be possible, but you would need someone who is prepared to sacrifice a two year old car in the name of science. (Right now I don't believe there is any pip over two years old.)
    #14 kenmce, Aug 12, 2014
  15. GregP507
    3,002
    481
    Without the benefit of long-term and rigorous and extensive testing, such as the manufacturers' perform, any jury-rigged, home-built contraption is just running on luck until it's visited by the inevitable unforeseen circumstances.
    #15 GregP507, Aug 12, 2014
  16. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Who wouldn't want faster charging? Charging level 2 at home and work still isn't always fast enough, some times. Based on everything written above, best to wait for the next BIG thing.
  17. bisco
    51,155
    peef, where are you?:(
    DadofHedgehog likes this.
  18. drees
    drees Senior Member
    1,782
    247
  19. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    Point #1 Yes you would need to Replace the charging box, (where the spare should be) &, probably the charger port connector and harness to the charger and redesign the relay module (located in the battery pack) because the relays that connect the charger and the bus bars that connect
    them to the main contactors are too small, and fabricate new wires between charger and relay module.
    Point # 2 This is a non issue as the pack sees much higher charge currents during regenerative braking.
    Point #4 ( not mentioned) You wold need to re program several of the car's computers which actually control the charging process.
    My conclusion is #4 would be VERY difficult as Toyota doesn't want it done!!
  20. Jimbo69ny
    712
    107
    Ithaca, NY
    What happened to point #3? haha
    iluvmacs likes this.
