Post-Drive stats.
Discussion in 'Gen 3 Prius Fuel Economy' started by HaminusMaximus, Sep 8, 2015.
  1. HaminusMaximus
    HaminusMaximus Junior Member
    Los Angeles
    I am driving myself crazy. I swore that my post-drive stat used to show me MPG/Miles/Cost.
    now it is showing MPG/Miles/Savings
    I've messed with settings to see how to get it to go back to showing cost. anyone know what I might have done to change it?
  2. Xterra72
    Xterra72 Senior Member
    1,399
    1,655
  3. HaminusMaximus
    Los Angeles
    Thanks for the link, guess i was just using the wrong search terms. i cant bring mine down to zero or xx.xx so i'll have to try disconnected the battery.
  4. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    All you need to do is to scroll through the different screens until you get to the bar graph that shows "ECO Savings Record". You will see either fuel cost or savings on the bottom right hand side of the graph. You can toggle between the two settings with the trip button.
    This will work on 2013 Gen III Prius and above. I can't say about the upcoming Gen IV. It will surely be different.
    Toggle with the trip button and the screen will change from fuel cost to savings.
    This is what it looks like when you shut down if you selected "fuel cost"
    This is what it will look like if you selected "savings".
    #4 dorunron, Sep 19, 2015
