Posted Time
Discussion in 'PriusChat Website Questions' started by Tom6850, Mar 13, 2007.
  1. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    In viewing new posts, the time posted in the "Last Action Column" is one hour ahead. ie: Actual time 6:32 EDT shows up as 7:32. Is it only me, if so how do I correct it?
  2. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    <div class='quotetop'>QUOTE(Tom 6850 @ Mar 13 2007, 07:35 AM) [snapback]404755[/snapback]</div>
    it's not only you
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    One of the many problems with the new time change.
    It is rather odd that it's correct on some parts of the site and not on others, however.
    *edit*
    nevermind... i could have sworn i looked yesterday and the post times were correct, but now they aren't...
  4. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    <div class='quotetop'>QUOTE(eagle33199 @ Mar 13 2007, 09:52 AM) [snapback]404785[/snapback]</div>
    I believe they were correct yesterday also. If it was an hour on the other side it could be the time change.
  5. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    You can correct it yourself by clicking the link near the top of the page "My Controls" and setting the time for the correct GMT offset (under "Board Setting").
  6. rufaro
    rufaro WeePoo, Gen II
    2,867
    72
    Lost Angeles
    <div class='quotetop'>QUOTE(Stev0 @ Mar 13 2007, 07:33 AM) [snapback]404801[/snapback]</div>
    Not true for at least some of us. Danny appears to be looking into it.
  7. hill
    8,207
    My brand new HD cable DVR boxes are off too. Like I'm sure going to try to set the recorder to compensate for that!
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    <div class='quotetop'>QUOTE(hill @ Mar 13 2007, 10:19 AM) [snapback]404896[/snapback]</div>
    The cable system transmits the time, so they need to fix it. I called my cable system around 10 a.m. on Sunday and left a message. Fifteen minutes later, the cable box updated.
  9. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    i just turned off the DST option in board settings and that fixed it. for now.
  10. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 13 2007, 02:53 PM) [snapback]404956[/snapback]</div>
    Bill, you are very lucky you can talk to someone!!!!!
  11. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Ok, here is what I have selected, and I am showing the correct time (currently 6:07 PM Eastern):
    The time (including your current adjustment) is: Mar 13 2007, 06:07 PM
    I selected GMT - 5 Eastern Time
    And then below that I have Auto Correct DST checked.
    I don't get why I'm showing the correct time using these settings but others aren't.... I'll keep looking.
  12. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Danny, I verified that my settings were as you described, but your message shows a post time of 7:09 as I write this ... at 6:22.
    Thanks for all your work!
  13. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    I didn't mean to cause a problem. Thanks for your efforts Danny to straighten this out.
  14. rufaro
    2,867
    72
    Lost Angeles
    <div class='quotetop'>QUOTE(JimboK @ Mar 13 2007, 04:22 PM) [snapback]405054[/snapback]</div>
    I just went in and UNchecked the autoadjust for dst and now it works...go figure... :blink:
  15. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(Stev0 @ Mar 13 2007, 09:33 AM) [snapback]404801[/snapback]</div>
    I did this a few minutes ago so that it's now set for London time. I sending this on Sunday, 18 March 07, at 12.12 p.m.
  16. jeneric
    jeneric New Member
    442
    Redmond, WA
    The board software apparently knows that DST came early and has already started this year. That's why our times are an hour ahead, instead of an hour behind.
    The UTC main time appears to be an hour ahead when I set to GMT+0 and turn off DST.
    I believe that it should be moved back an hour so that it maches this:
    http://www.time.gov/timezone.cgi?UTC/s/0
  17. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    OK, THIS is weird. It's now 11:37 my time. I just made a post. When I look at the list, though, it says "Last post made: 10:35." So I figure the board is doing wacky DST things again, so I bump up my time offset by exactly one hour. I go back into the forum and it says "Last post made: 12:35."
    Weird. Eerie.
  18. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    I've been out of town for the last 5 days and when I opened Prius Chat I noticed that the "posted time" is correct again. How did this come about, a fix or just happened?
  19. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(Tom 6850 @ Apr 20 2007, 02:29 PM) [snapback]426924[/snapback]</div>
    Not for me. I'm posting this at 10.56, London (EU) time. on 21 April.
