Posting Dr. Prius stats for the first time - How are these?
Discussion in 'Gen 3 Prius Technical Discussion' started by kfbjskdlelejklehdffv, Jul 9, 2023.
  1. kfbjskdlelejklehdffv
    kfbjskdlelejklehdffv Junior Member
    16
    Jerusalem
    Hi!
    First time I ran this test. 2011 CT200h (same as 3rd Gen prius).
    Was wondering if anyone can tell me if these are ok?
    I am actually trying to determine the health of the battery, but I didn't realize the test requiring purchasing the full app.
    Thanks!!!
  2. PriusCamper
    PriusCamper Senior Member
    13,049
    5,303
    Pacific Northwest, USA
    Everything looks fine... The number to pay attention to is "Volt Diff" as your pack gets older that number will go higher under heavy amp loads. Once that number gets up over 1 volt you get warning lights and hybrid system shuts down until lights are cleared.
    kfbjskdlelejklehdffv likes this.
  3. kfbjskdlelejklehdffv
    16
    Jerusalem
    Thank you so much.
    Very interesting. Volt Diff. This was when the car was stationary. Should I check this again while the car is under load (driving and powered by the electric motor)? Will it make a different?
    Thx again!
  4. PriusCamper
    13,049
    5,303
    The amp number above makes voltage difference go higher when it goes higher...
