Posting from the side of the road, could use some advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wowbobwow, Jul 12, 2015.
  1. wowbobwow
    wowbobwow Junior Member
    34
    Bay Area, California
    2016 Prius v wagon
    I've got a 2008 Touring Edition with 99.5k miles. Just had the HUGE, expensive 100k services performed by my local dealership this past week, including new belts and water pump. Picked it up on Wednesday and now this. :-(
    Was driving along on the freeway just now when my dash lit up with the big red <!> symbol along with a temp / coolant symbol. Pulled over and now I see what looks like coolant sprayed all over the engine compartment, steaming away.
    I'm gonna call the dealership and explain the situation, but since they've shown nothing but horrible service so far, I'm not confident that I'll get far. Any info you guys can suggest before I call (the service department doesn't open for another hour) would be great.
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Can you do a quick visual check and see if the belt is still in place?
    There have been similar cases reported here where the belt wasn't tensioned correctly and came off soon after the service.
  3. wowbobwow
    34
    2016 Prius v wagon
    Hi uart- thanks for replying!
    As best I can tell the belt is still there. There is pink fluid sprayed all over the passenger side of the engine compartment and pooled in all the lower areas below the engine. I noticed yesterday that the passenger-side headlamp has been turning off, and only coming back on when I manually fiddle with the switch. I can now see that the fluid (I'm guessing coolant but can't be sure) has been sprayed / dripped all over the cables leading to the headlight. Arrrrrgh.
    49,738
    sounds like they didn't correctly install something. can you gt the cover off the radiator to look under the cap after it cools off?
  5. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Ok, then it sounds like the new water pump was faulty (or a faulty install) and it has leaked badly. It mightn't be too bad, if you stopped as soon as the lights appeared then there is a fair chance that you've got a nice mess but no actual engine damage. The dealer should clean it all up and replace the pump and coolant. Hopefully there's no other damage done.
  6. wowbobwow
    34
    2016 Prius v wagon
    Very helpful - thank you! Just took a look and as far as I can tell the coolant tank (white translucent plastic one) is completely empty. Yay.
    I did immediately reduce speed (was doing ~70 when the errors happened) and took the next available exit, so I'm guessing 3-4 minutes between error and parking. Hopefully not enough to have damaged anything beyond the point of failure...
  7. JC91006
    16,496
    8,406
    Have the dealer tow it back to them
  8. bisco
    49,738
    whatever damage there is, it's their responsibility. all the best.(y)
  9. Patrick Wong
    18,200
    6,479
    Tell us which dealership this incompetent service department is associated with, so that other SF Bay Area members will know to avoid it.
  10. wowbobwow
    34
    2016 Prius v wagon
    Patrick - it's One Toyota of Oakland. Incompetent service technicians managed by clueless idiots. Inconsistent quotes, no callbacks to messages, left my car covered in grease (including on the dashboard and door panels), etc. Utterly ridiculous.
  11. bisco
    49,738
  12. Patrick Wong
    18,200
    6,479
    Thanks - you have two independents in your area - Art's Automotive in Berkeley, and Luscious Garage in SF.
    I don't know the Toyota dealerships in the East Bay, but when I lived in Sunnyvale (from the late 70's until 2000) the Toyota dealers in that city and Cupertino were OK.
