Potential 2014 c purchaser - any major issues?
Discussion in 'Prius c Main Forum' started by Nathgreene, Jan 23, 2025.
  1. Nathgreene
    Nathgreene New Member
    United States
    2014 Prius c
    Hey folks,
    I’m on the hunt for a nice reliable car that will last me 5-10 years without (many) major expenses. A friend of mine is selling a 2014 Prius C with ~140k for a very fair price. But I’ve never owned a hybrid before so I’m getting worried about it (especially electrical issues and getting replacement parts 5 years from now).
    Is it pretty easy to find parts for your Cs? Are they more expensive for repairs than non-hybrids because of the complicated electrics? And are they less reliable/long-lasting than non-hybrids?
    Thanks a lot in advance! Already learning lots from the forums.
  2. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    My 2012 C that I bought new has been the most reliable car I have owned in 50 years of buying vehicles, and most of those were Hondas. I recently hit 185000 miles, and until three weeks ago had spent a total of $400.00 on repairs that I wouldn't consider normal maintenance - a hub/bearing assembly and an AC recharge.
    What happened three weeks ago was that I found my rear axle beam had rusted out to the point it had to be replaced. This appears to be a common issue with the C and some other Toyota models that use the same axle. How long it will last probably depends on how much salt or other corrosives it gets exposed to. Despite the fact that all 8 years of the C, 11 years of the Yaris, a few of the Scion and I think 1 year for a Lexus, and possibly some older Prius years use the identical axle, the typical sources like NAPA, Auto Zone, and O'Reilly didn't offer the part. Fortunately, some other sources have filled that gap. My repair shop gave me two prices, one using a Toyota dealer part and the other, several hundred dollars lower, using a part they obtained elsewhere that had to come from out of state. Installed cost was $1300.00. This is probably something you should check on that 2014. Poke it with a screwdriver as the rust may not show. I doesn't mean you shouldn't buy the car if there's rust. It will just alert you to a repair coming down the road.
    Two other costly repairs you could face are the hybrid battery itself ($3500 from a dealer or $1800 or so from aftermarket companies) and any parts needed to fix the AC. If the AC is blowing cold you are probably OK there, although there's no guaranty. AC parts are expensive on most cars these days. The remaining life of the hybrid battery can be checked at a Toyota dealer, or there is a phone app called Dr. Prius (Google it) that with the help of a $10.00 OBD II module can give you the same result. Or if your friend has already replaced it, you can probably skip that test.
    A through inspection and test drive should expose most other issues. Except for the unusual situation with that axle, I haven't heard of any problems with parts availability. The car shares other parts with the Yaris and Scion. Since I have only replaced what I described above, maybe others can respond with more info in regards to parts availability issues they have had.
    In general, I consider hybrids (at least Toyota hybrids) to be more reliable and less costly than non hybrids simply because there are fewer parts to go bad. There are no belts to break, no starter or alternator to fail, and brake pads last twice as long. I replaced my front discs at 115,000 miles (rotors were fine), and I'm still riding with the original shoes in the rear. I wouldn't hesitate to buy another hybrid.
    #2 rjdriver, Jan 26, 2025
    Nathgreene and Adventurer2112 like this.
  3. Nathgreene
    United States
    2014 Prius c
    Thanks for the thorough and helpful response!!
    52,394
    5-10 years on top of 140k will probably involve some costly repairs. not the cars fault, but hybrid repairs are pricey
    Nathgreene and BiomedO1 like this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,155
    2,178
    SacTown, Ca
    Your probably better off with a gas only Honda or Toyota. They're easier to fix - especially if it's 10+ years old with equivalent miles. In my experience; things usually starts breaking around 150K. Your expecting another 5-10 years and how many miles? Do you live in snow country that salts the roads? That also effects how long a car will last.....
  6. Nathgreene
    United States
    2014 Prius c
    The *hybrid* repairs especially were one of my big worries. Obviously every car needs repairs, but some more costly than others! Thanks.
    BiomedO1 likes this.
  7. bisco
    52,394
    agreed. and on top of the expense, the number of shops that are willing to work on hybrids is very limited, making service difficult
    Nathgreene likes this.
  8. Leadfoot J. McCoalroller
    8,149
    7,652
    Pennsylvania
    2018 Prius c
    New and young hybrids are AMAZING for low cost, ultra-reliable operation.
    Older hybrids are... not.
    A 2014 c isn't terribly old. You can still get another 5-10 years out of one.
    Be aware that the hybrid batteries in that model tend to last ~10 years. So you should accept the fact that while the hybrid battery in a given candidate may seem fine today, it is statistically near the end of its service life and you should budget accordingly.
    If it still looks like a good deal, go for it. They really are nice smooth cars, at least if you're into buzzy subcompact hatchbacks.
  9. Nathgreene
    United States
    2014 Prius c
    Thanks everyone for your input! We decided to buy a 2017 corolla to avoid the old hybrid hullaballoo. Hopefully it will live long a prosper!
