PotHole Damage
Discussion in 'Gen 2 Prius Main Forum' started by JoeVentu, Mar 12, 2006.
  1. JoeVentu
    JoeVentu New Member
    Well, only 2000 miles on my Prius and I hit a pothole last night (could not see it in the dark) and let me just say this: I have been driving for 30 years and I have NEVER hit anything like that! The Prius bottomed out and the front tire blew. I really cannot tell if there is suspension damage, but I think so..rotor and caliper seem to be grinding. The good news is that it is easy to change the tire..even in darkness. I will keep you posted as to the damage and repair costs
  2. KTPhil
    KTPhil Active Member
    1,379
    Insist on a four wheel alignment (including normally non-adjustable parameters: toe, caster, camber), and of course replacement not straightening of any parts. Check for bent sheet steel frame members also. Get the alignment printout in writing and keep it.
  3. Begreen
    Begreen Member
    670
    Western WA state
    KTPhil has it right. Get whatever done to make it perfect and document everything very well. My sister in law had a similar incident many years ago in CT. She pressed the town for the damages and got them reimbursed + she got the hole repaired.
