Power brakes went out while stopped with foot on pedal.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tmorrowus, Feb 7, 2022.
  1. tmorrowus
    tmorrowus Member
    514
    I drove 15 min to a post office, powered off the 2004 Prius, dropped my package off, started the prius, and had my foot on the brake for a few minutes while dealing with notifications on my phone.
    I felt a strange sensation through my foot on the brake, as the pedal got mushy all of a sudden. I didn't think much about it, started driving away, and noticed the brake felt super mushy and stopping distance was way longer than it should be. I also noticed that the red Brake Light was on, and three yellow warning lights were on: "Warning", "VSC", and one other next to or between those that I can't remember now.
    I pulled off the road, powered off the Prius, powered it back on a few seconds later, and nothing had changed: still mushy brakes and same warning lights. I powered off, waited a few minutes, and powered back on. This time everything was normal: the brakes were stiff and powerful, and no warning lights.
    I pulled out a bluetooth OBDII scanner from my glove compartment, but couldn't see any codes thrown or in the history. Since I'm not very familiar with the OBD Fusion app, it could have been user error but I spent 5 minutes digging around and I have easily found codes in the past.
    Any idea whether I should be worried? This is the first time this has ever happened since I bought the 2004 new.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Is it beeping too?
    I'm afraid you may have a failed ABS unit. Its a very bad very well known and very expensive issue that most G2 owners in the know dread.
    You will hear the vacuum pump go non stop sounds like a rattle snake as the ABS unit has sprung a pressure leak. Hope its not that..
    Use the search forums link up top and search
    ABS
    Lots of posts about it.
    SFO likes this.
  3. Aegean
    Aegean Active Member
    423
    184
    Alexandria VA
    It sounds like the brake actuator. You can confirm with reading the codes with a proper OBD2 reader capable of reading all Prius modules.
    See videos on YouTube to understand level of effort for replacement.. Unfortunately, this is a common but very expensive repair. You need to use a new OEM actuator because used and refurbished fail often. Labor is also ridiculously complicated on this car. Very tough for most shops and experienced DIY.
  4. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Not sure how compatible that App is, best to find another that can do the job, or grab a mini-vci cable and techstream (dealer tech software).
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,100
    5,812
    Columbia, SC
    Before you go freaking out about this, it would be wise to get the actual codes provided by the car.
    I don't recall a Gen 2 having a vacuum pump anywhere in the brake system.
    The ABS module has an electric motor driven hydraulic pump. The pump runs and fills an accumulator, which is the supply source for braking pressure. Once the accumulator is at its max pressure setpoint, the pump turns off and the accumulator continues to supply pressurized fluid for braking action. As the brakes are used, fluid flows out of the accumulator and its pressure drops, eventually reaching the low pressure setpoint, where the pump starts again. If the system develops a leak or the accumulator fails to hold pressure, the pump has to run more often to restore pressure. At some point, the pump may have to run continuously to maintain pressure. That's when the loud chime starts kicking in. If you're not hearing that chime, hmmmm........maybe something else is going on. There are more components in the system than just the actuator module.
    In a properly operating system, you can hear this "cycle" just by putting the car in ready and pressing the brake pedal a few times. You should be able to hear the pump start, run for a few seconds and then turn off. Once the accumulator is charged, if the brake pedal is not pressed, the pump should stay off. This is one check that can be performed when buying a Gen 2.
    In a leaking system, the pump will start and stop frequently, even without pressing the brake pedal.
    tmorrowus and jerrymildred like this.
  6. tmorrowus
    tmorrowus Member
    514
    Thanks for the info, all!
    No beeps, just lights. IIRC I did feel sort of a vibration in the brake pedal similar to when ABS activates while braking from speed, even though I was stopped, right before it got mushy.
    Good idea. I'll bring the car to an auto parts store or dealer who will have a proper code reader.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    And while you are there, test the 12 V battery and the charging voltage too.
    And make SURE that they actually have a code reader that is compatible with your Toyota Hybrid.
    I bet that many places don't really know.
  8. ChapmanF
    15,105
    The good news about trouble codes for the brakes is you can get them with no scan tool at all, just by using a short piece of wire to connect the Tc and CG terminals at the diagnostic port, and counting blinks on the dash lights. (A little searching will find you many posts here with the rest of the details.)
    It is more convenient to use a scan tool if you have one (and the one you have works and gets you the codes). But if you've got brake issues and no scan tool handy, or the one you've got isn't getting you the codes, then it is more important to find out what the codes are than to wait for a better scan tool to arrive, and the blink codes let you do that.
  9. tmorrowus
    tmorrowus Member
    514
    Good points. I'm heading to the Toyota dealer in 15 minutes. They did test my Optima Yellow Top a month or so ago and it was above spec. But one of the posts is cracked from when I dropped it trying to install it, and very fragile. So it is conceivable that could reduce the amps available to the braking system, especially while parked. I will have them test it and I suppose I ought to bite the bullet and replace that battery even though the capacity is fine. It's 7 years old and I have gotten more life out of the Optima Yellow Tops in the past, but potentially losing braking power seems like a very good reason to replace. Autozone seems to have a decent price at $279 delivered to the store.
  10. sam spade 2
    7,035
    2,783
    2017 Prius c
    I think it is time for a new one. 7 years is a good life even from the best batteries.
    Note, however, that from reports here and other forums, the quality of the Optima batteries seems to have steadily gone down hill in the past few years and if you get another one now it likely to be nowhere NEAR as good as what you have had in the past.
    tmorrowus likes this.
  11. tmorrowus
    tmorrowus Member
    514
    Argh. The Toyota dealer found a code C1357: "Decreasing Pressure Solenoid Malfunction Front Left " in my recent history (but it was not "thrown" which is probably why OBD Fusion didn't present it to me):
    C1357 Code Decreasing Pressure Solenoid Malfunction Front Left
    They suggested I replace that actuator for $3100 including labor. I was hoping to keep this car at least a few more years, until a new generation of plugin hybrid Prius or other vehicles gets released and supply chain issues ease.
    I have a very nice stereo system recently installed which would cost about $3k to transfer to a new car. I have done all the required maintenance since I bought it new. So the car has much more value to me than it would to someone I would sell it to (if I even could). I think I'd be willing to put $3k into this car for a few more years service. It's a lot less than the payments and insurance for a new car.
    However, if these actuators are all going to start going bad around the same time, that means four actuators (one for each wheel), and that would probably be reason to let this car go. I'll go read up on this actuator situation. I'll also retest my high voltage battery with the Dr Prius app to see if that's still OK.
    For now my thinking is to go ahead and replace the battery with an Optima Yellow top; it's about the same cost as the OEM dealer battery after discounts, about $300 all in. It does seem possible that low voltage could have caused a marginal actuator to have that failure and throw the code, and that higher voltage might keep it reliable for a few more years. I don't hear the hydraulic pump running often as others with failing actuators have reported, but I haven't been listening for it either.
  12. sam spade 2
    7,035
    2,783
    2017 Prius c
    I thought I told you about the poor recent track record with Optima batteries.
    If not, they do NOT have a good reputation lately.
    Almost any other brand would be a batter bet.
  13. BuyJapanese
    BuyJapanese Member
    61
    30
    Wisconsin
    Could still be 12v battery or skid control ECU right? I agree, replace the battery. Also practice using the "B" engine brake in case your brakes totally fail on the highway! Remember in an emergency situation you can gradually press down on the parking brake foot pedal too.
  14. ChapmanF
    15,105
    C1357 (which also shows as 2-4 blinked on the ((!)) light if you aren't able to read it with a scan tool and use the jumper wire method instead) indicates an electrical issue in controlling the SLRFL solenoid.
    Here it would be helpful to have a scan tool that can retrieve the INF code; there are four possible for C1357.
    INF 26 means an open circuit to the SLRFL solenoid was detected for at least a twentieth of a second while the solenoid was supposed to be off.
    INF 27 means the same thing, but while it was supposed to be on.
    INF 28 means a voltage leak or short to +B was detected for at least a twentieth of a second.
    INF 29 means the solenoid drew excessive current for at least a twentieth of a second.
    If I had to place a bet from the symptoms described here, my money might be on 28, but I'd rather read the INF code than gamble.
    There are more "actuator' threads here about mechanical failures; you might have some trouble finding other threads about this situation, which is less common.
    Because these are electrical issues, when you follow the workup steps in the repair manual (more info), the very first checks are made with an ohmmeter at the terminals of the brake actuator and with a voltmeter at the terminals of the skid ECU, with an eye to finding out whether the wiring or connectors are at fault, or the actuator needs replacement, or the ECU does.
    Do you know whether the dealer did any of that, or just read the code and decided to sell you an actuator?
    (They can't, by the way, sell you "an actuator for each wheel"; all those different solenoids are part of just the one actuator assembly, which is the only thing that gets replaced, if it's the problem.)
    This has to be done really, really carefully because of the one-way ratchet in the parking pedal, putting you at risk of a loss of control that you can't correct by instinctively lifting your foot. If this is something you think you ever might do, you can practice it (under safe conditions) where you start with a quick double-jab of the pedal to disengage the ratchet, and then you have control that you can both apply and release, like a regular brake pedal (except you can't let it all the way back up, or the ratchet is armed again).
    If that isn't something that you practice regularly, an emergency probably won't be the best first time to try it.
    BuyJapanese likes this.
  15. tmorrowus
    tmorrowus Member
    514
    Very useful info here.
    I have no indication that the dealer read the INF code. Sounds like I need a second and third opinion.
    Thank you! I am now pretty sure the dealer service rep didn't fully understand everything he was talking about. He made it sound like the replacement would only fix the one wheel, but all my web research agrees that there is only one actuator assembly for the whole car. This is encouraging, as is the fact that I may not need one at all because it may not be the mechanical leakage issue that seems so common.
    Edit: I just emailed the dealer to ask if about the INF code and the Ohmeter tests.
    #15 tmorrowus, Feb 10, 2022
  16. tmorrowus
    tmorrowus Member
    514
    I will look into that. But my experience was that Optima batteries lasted nearly twice as long as the other batteries, so even if the Optima only has half the life as in the past that just puts it even. And the Optima is the only one rated as deep discharge (to my knowledge), which is important with the high powered stereo system I have; I always keep the engine on ready when listening, but my system can suck down more watts than the inverter can supply so even then can drain the battery.
  17. Aegean
    423
    184
    Alexandria VA
    Another option for this situation is to sell the 2004 Prius as is for $1500. Then add $3100 you would pay for actuator and $200 for the 12v battery and you have almost $5k for a replacement vehicle. There are a lot of much newer reliable vehicles at $5-10k that would last several years.
  18. ChapmanF
    15,105
    By the same token, if your troubleshooting ends up leading to a slightly munched wire or corroded terminal in the SLRFL circuit and you fix that, you could have a reliable vehicle for $5-10k less than that.
    So a lot rides on what the issue turns out to be.
  19. tmorrowus
    tmorrowus Member
    514
    Okay, big update.... TLDR I'm going to have to replace the actuator and so now looking for best deal on that.
    So the dealer who did the test that I reported in post #11 got back to me and said the INF code was 26, and I think mistakenly told me that the actuator and ECU were one unit and both would have to be replaced together so no point in trying to figure out which was at fault. Since I'm pretty sure this is not true, and this was not the first distortion he communicated, I gave up on this dealership and went to another Toyota dealer, where I paid $170 to have them do a detailed diagnostic.
    BTW the inept dealership was brand new with a high end hotel like waiting room, while the Penske Toyota dealer below who seemed competent had an old trashy waiting room that felt like a bus terminal.
    This time I got to speak with the actual service tech for 15 minutes, answering all my concerns and getting really good info. He said that the "C1357 Decreasing Pressure Solenoid Front Left" which was current but not thrown in my car was associated with DTC (Detailed Code) 28 which I guess is the INF code:
    28: Short to +B or voltage leak in SLRFL continues for 0.05 sec or more
    He said it is possible that the 26 code the other dealer reported could have been from another freeze frame, although my sense is that it was probably just a telephone-game typo, but for the record I'll note that code works out as:
    26: Open circuit in SLRFL continues for 0.05 sec or more when SLRFL is off.
    This knowledgeable tech showed me the freeze frame data pulled from the car when the C1357.28 was thrown, which showed voltages on +B1 and +B2 both measuring 14.03V, which I think he correctly interpreted to mean that my battery voltage was not what caused this.
    • He said that a defect was discovered in the manufacturing of the actuators at some point, and that the newer ones made after the defect was corrected have a different part number from the potentially defective ones.
    • So I definitely want one of the newer ones if I replace mine.
    • He said he has seen vastly more actuators than skid ECU's go bad. He didn't say but I inferred that the troubleshooting steps that say to test the ECU first were probably written before the actuator defect was known.
    • As far as testing the wiring and skid ECU, he said that it would require $700 of uninstallation to access the ECU terminals. And...
    • The ECU tests would also only be useful to do while the code was THROWN (and dash light on), but wouldn't serve any purpose if that code and light weren't currently on, which is my situation.
    • He said that he suspects the root cause of my actuator failure is the same accumulator issue that most people are seeing and which was covered by the recall. But because
      • my C1357 code is not one that was covered by the recall
      • the recall only applies if the dash light is on and code is thrown (not just current).
      • my 185k mileage is over the 150k limit for the recall
      • IIRC the 18 year age of my car is over the age limit for the recall
    • He didn't think my chances of getting Toyota to fix it on their dime were very high, although I could try.
    • As far as the safety of driving the car in the current condition, he noted that as long as the dash light is not on, the system is working properly. But if the dash light is on (as it did for me temporarily), then I need to immediately stop driving it. He did note that many people drove their cars into the shop with the light on and just manual brakes, but that is outside my range of comfort.
    • This dealership's estimate for replacing the actuator was $1074 labor, $1900 parts, 61 misc which works out to $3197 with tax. I didn't bother haggling with them since I'll probably find an independent shop to
    I spent this morning testing my car with Dr. Prius checking the High Voltage Battery.
    • Out of five "Full" tests, four showed completely passing results, while the second showed the following under "bottom voltage:" Warning! Suspected problem block 7,8,13,14, [and the rest was cut off of the screen]. I think I'm willing to chalk up that one apparent failure to random fluctuation out of statistical ranges.
    • The "Lifetime" (capacity) test results for three tests were: 58.29%, 51.67% (this test was interrupted about halfway through by engine starting), and 54.94% (this test was interrupted about 3/4 of the way through by engine). For reference the results screen says: 90% new, 70% good, 50% fair, 40% poor, lower than 40% need replacement soon. A few years ago my result was about 60% so I think it's reasonable to assume that at this trajectory it is not unreasonable to hope for at least a few more years out of the battery.
    So unless there's something I'm missing, I'm going to keep this car and replace the actuator. I ordered a new Optima Yellow Top from O'Reilly for $279 list plus core, shipped to dealer hopefully in one day.
    I will start reading old posts about best deals for actuators, but if anyone has advice they want to share here I'd be much obliged. I'm new to NW Austin and if anyone happens to know of a good hybrid shop please let me know.
    #19 tmorrowus, Feb 11, 2022
  20. ChapmanF
    15,105
    Hah! Now I wish I had placed that bet. :D
    The reason that seemed most likely to me was that you described a problem with pressure being lost while your foot was on the pedal. SLRFL is a pressure releasing solenoid, so that would be explained by a short to +B causing the solenoid to open and release pressure.
    Right, there was never much serious chance of that.
    He might not want to do that testing (and you might not want it to be done at his hourly rate), but see below ....
    I can't agree with him a hundred percent on his policework there. The "issue that most people are seeing" has involved mechanical wear that allows pressure to leak off. It has not been an electrical short that stimulates a release solenoid, as you have here.
    ... which could have been his first clue that your issue is not that issue. :)
    So, this is the "see below" part about the electrical testing. The actuator is both a chunk of change to buy and a chunk of labor to put in. You would probably feel pretty disappointed if you spent that amount of money and labor to put a different actuator in, and then noticed the replacement still letting your brake pressure off sometimes because there's still an electrical short to +B somewhere, stimulating its release solenoid.
    So the let's-avoid-disappointment path here is to find out where that electrical short is. If it's in the actuator itself (sure, that's one possibility), then you could proceed with actuator replacement with confidence it was really the problem. If it's in the ECU, you can replace that, and if it's in the wiring, you just fix that and call it a day, without any big-ticket parts.
    SFO likes this.
