Power button
Discussion in 'Gen 2 Prius Main Forum' started by powphilprius, Sep 21, 2007.
  1. powphilprius
    powphilprius Elshawno~
    72
    Albuquerque
    :p That new something I learned today (or did I miss this in the manual?). You can power up the whole system & drive after a non-hybrid system power up (pressing the power button twice without your foot on the brake to get windows, radio, etc). Press the brake & push the button again (a third time) & its fully on! So the question is has any one else been doing this & does it provide any benefit?
  2. Tideland Prius
    16,195
    welll.. no other than you don't have to turn the car "off" before starting the car. Anytime you press the brake pedal and the POWER button (whether you're in OFF, ACC or IG-ON), the car will go into READY mode (i.e. will start)
  3. powphilprius
    72
    Albuquerque
    Thankyou. I was thinking perhaps one benefit might be less battery drain while sitting stationary.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Thanks for confirming that for me, I noticed this just yesterday but wondered if I pressed it twice.
  5. Tideland Prius
    16,195
    <div class='quotetop'>QUOTE(powphilprius @ Sep 20 2007, 10:51 PM) [snapback]515636[/snapback]</div>
    Yeah it helps so you don't drain the 12V battery.
    Do note that if you're in ACC mode (the first press without the brake pedal), it will automatically shut itself off after 1 hour. It freaked me out the first time it did it.
  6. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    All together now,
    "My car is smarter than me, my car is smarter than me."
  7. dogfriend
    7,512
    1,187
    Carmichael, CA
    <div class='quotetop'>QUOTE(David Beale @ Sep 21 2007, 11:35 AM) [snapback]515884[/snapback]</div>
    My car is smarter than you, my car is smarter than you. :p :D :lol:
  8. Tideland Prius
    16,195
    <div class='quotetop'>QUOTE(dogfriend @ Sep 21 2007, 02:29 PM) [snapback]515947[/snapback]</div>
    :lol: :lol: :lol:
  9. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    i noticed if i press the power button twice without my foot on the brake, it powers up, but it won't go into drive, just neutral. You have to start it with your foot on the brake for it to go into drive.
  10. dogfriend
    7,512
    1,187
    Carmichael, CA
    <div class='quotetop'>QUOTE(Rangerdavid @ Sep 21 2007, 07:43 PM) [snapback]516047[/snapback]</div>
    There is a chart in the service manual that shows how the shift lever works:
    In ACC, you can shift to P if the car is in N (don't ask me how you would be able to do this since the car shifts to P when you power down)
    In IG-On, you can shift from P to N and N to P but not to D or B. (edit: or R)
    In Ready, from P you can shift to any position except B. You have to be in D to shift to B.
    [attachmentid=11589]
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    cool little chart, albeit a bit confusing at first.
    I've been using neutral a lot more recently and discovered the inability to go into B from N...as indicated on the chart.
  12. darelldd
    6,057
    389
    Northern CA
    Errr... that was the point of this thread, me thinks! Without your foot on the brake, it does not "power up" - meaning it does not go into ready mode. You only get that when you put your foot on the brake first.
  13. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    <div class='quotetop'>QUOTE(Tideland Prius @ 2007 09 21 09:39 AM) [snapback]515836[/snapback]</div>
    Oh, it's on a timer. I've noticed the shutoff, too, but thought it happened when the battery got low. When sitting listening to music, I power down to turn off the headlights, then go back into ig or acc mode, whichever it is.
